Author Topic: 16v top end noise!  (Read 3406 times)
Offline blu16v
  • 1987 Mk2 16v + 1996 Mk3 8v
16v top end noise!
« on: 29 May 2004, 17:00 »
I have looked thro' the forums and can't find an answer so i decided to join and pose this question.
I recently bought an '87 16v, 135,200 mls, done very little mileage since bottom end rebuild 2 years ago.
I think the timing is out, it doesn't like spinning over when hot, starts OK when cold, appears to run rich and when the revs are increased to over 3k it sounds like a bag of nails in the vicinity of the distributor.
I initially thought it might be the seized weights in the dizzie causing it to pink, but after acquiring and reading a Haynes, i discovered the cam has a chain drive.
Do these chains suffer from wear?
Offline mk1
Re:16v top end noise!
« Reply #1 on: 29 May 2004, 18:01 »
Hi blu,
Yes the chains do wear and make a lot of noise, there are no weights in the distributer as there is a ign ecu that looks after the timing. You still have to set the base timing in the usual way, cant remember the settings but should be well covered in your Haynes manual.
Steve.
Offline blu16v
« Reply #2 on: 29 May 2004, 18:10 »
Thanks for response Steve, I guess i'll look into getting a new chain and fitting it as it sure doesn't sound healthy.  >:(
Apart from that appears to be a good 'un, no smoke or leaks anywhere.
Offline tinman
« Reply #3 on: 29 May 2004, 22:33 »
The easiest way to confirm if it is the chain is to listen to it - and think does this sound like a fast moving chain? - sounds really dumb, but once you know there is a chain on the right hand side of the engine the noise makes more sense.
slack cam chain on 16v is more common than people think. the chain costs 40quid. once you've replaced it - you'll hear all the other noises. like the tappets.
Veedubgt18v
« Reply #4 on: 30 May 2004, 10:44 »
and you will think you got an old diesel :(
Offline blu16v
« Reply #5 on: 30 May 2004, 17:44 »
Where did you get ?40 quid from? Euro Parts advertise the chain for ?8.95. Is it best to buy a genuine VAG part?
I can already hear the tappets, they do quieten down after running a while. What's involved in changing the shims?
Thanks
Doug
Offline mk1
« Reply #6 on: 30 May 2004, 19:51 »
Tappets on 16v engines are hydraulic, no adjustment. Give the engine a flush and change the oil and filter. The cam chain is less than a ?10
Steve.
Offline tinman
« Reply #7 on: 31 May 2004, 12:14 »
VAG Counter price at the time. Personally - wouldnt put non VAG parts in the engine if you can get away with it. No point.
Veedubgt18v
« Reply #8 on: 31 May 2004, 13:13 »
yeah i would agree with tin. changing tappets isnt hard if you are prepared to get your hands dirty
