Author Topic: RE: spluttering/running poor whilst driving.. 2.0 16v abf  (Read 6707 times)
Offline Overseer
Re: RE: spluttering/running poor whilst driving.. 2.0 16v abf
« Reply #10 on: 21 November 2008, 14:06 »
ok.. well i know where one end starts, so i can follow it through..
have a feeling its been replaced before.... and maybe even been "reinforced" at the throttle body end with a bit of zip tie
Offline Overseer
« Reply #11 on: 21 November 2008, 15:23 »
ok.. so standing looking directly at the engine bay.. the one in question leaves right out the back of the inlet manifold, right off into the bulkhead..
if so mine is fairly frayed, and has some zip tie on it.. then disappears off into the bulkhead
but i cant see how to follow it further easily...  how do i get in there?
Offline Len
« Reply #12 on: 21 November 2008, 16:14 »
You have to take out the plastic tray above the pollen filter and ECU. There is a rubber strip first that just pulls off then you have to be careful getting the end of the plastric tray out from the bonnet hinge! I broke mine doing this!
You may have enough space to just lift the tray once you have pulled off the rubber strip so try that first!
The pipe goes to the ECU which is roughly in the middle.
www.sas.org.uk
www.the-ace.org.uk
Offline Overseer
« Reply #13 on: 24 November 2008, 11:39 »
looks like i need to do this one...
ebay vag-com just turned up and.....
1 Fault Found:
00519 - Intake Manifold Pressure Sensor (G71)
        03-00 - No Signal
got it from this guy...
http://cgi.ebay.co.uk/USB-VAG-COM-409-1-OBD-2-II-CABLE-LEAD-AUDI-VW-VAG-COM_W0QQitemZ320264176020QQihZ011QQcategoryZ30921QQcmdZViewItemQQ_trksidZp1742.m153.l1262
works fine on my laptop which runs vista :)
« Last Edit: 24 November 2008, 11:40 by Overseer »
Offline Overseer
« Reply #14 on: 24 November 2008, 14:37 »
after looking around on the interwebs i found that the "00519" can also be solved by swapping out the ECU relay
so i did that quickly.. and went for a quick rag.. no problem so far.. but time will tell..
got some vac tubing too..
jamie16v
« Reply #15 on: 26 November 2008, 20:15 »
just replace the tubing, i replaced the relay weeks before i replace the tubing, i thought the problem went but as it was a desquised intermittant fault, it just came back when i was on a long journey again..
as soon as the pipe was replaced the fault has never appeared again and the engine now runs sweet as a nut.
Offline Overseer
« Reply #16 on: 27 November 2008, 08:35 »
i'm planning on doing that too.. but so far we're on day 3 of no stuttering AND no ABS fault, whereas from thurs last week through to the morning I changed the relay it was playing up.
havent put my laptop back on it yet either..
Offline stokedout
  • Get ya spannerz oot
« Reply #17 on: 05 August 2009, 10:45 »
I'm getting this problem on my 2.0 16v too.
I want to buy a replacement pipe, where did you get yours?
Offline Overseer
« Reply #18 on: 05 August 2009, 10:46 »
dont have my golf anymore, but i got it from vw.
the thing that fixed my car in the end was the relay.
Offline stokedout
« Reply #19 on: 05 August 2009, 14:29 »
Cheers mate...
Just rang them £8.50 a metre. I'll see if I can get it elsewhere before
paying VW over the odds.
Actually Just got price motor factor shop £2.50 a metre -  :wink:
