Author Topic: aaaaaaaaagh!  (Read 963 times)
Offline SODA
aaaaaaaaagh!
« on: 28 October 2008, 23:14 »
can somebody help me before i go insane.  i have a 8v mk2 gti and every slightest bump in
the road sets my windscreen washers off even when i turn the wheel full
lock there it goes over speed ramps etc, is there anything can be done?
Offline nikkyboy
Re: aaaaaaaaagh!
« Reply #1 on: 28 October 2008, 23:37 »
Check your stalks, they can wear out at the base.  Give it a nudge at the base and see if it sets the washers off.  This used to happen to mine exept i'd get a plume of smoke off the steering column  :shocked:
If its that then GSF and Eurocarparts do spares.  New ones solved the problem for me. :smiley:
Offline NEWEY
Re: aaaaaaaaagh!
« Reply #2 on: 29 October 2008, 07:50 »
if you replace your stalk it will sort it out :) i had the same problem
« Last Edit: 29 October 2008, 13:05 by NEWEY »
Offline JC
  • Back in the North.
Re: aaaaaaaaagh!
« Reply #3 on: 29 October 2008, 12:22 »
if you replace your stork it will sort it out :) i had the same problem
lurpack or clover ?? ?? ?? ? ? ??
 :laugh: :laugh: :laugh: :laugh: :laugh:
Offline Organisys
  • Old and Slow...
Re: aaaaaaaaagh!
« Reply #4 on: 29 October 2008, 12:35 »
Also check the relay for the wipes is secure.
Offline spacerat
Re: aaaaaaaaagh!
« Reply #5 on: 29 October 2008, 23:13 »
neones from gsf are about £45 if its an mfa stalk. or go second hand for £5 llike me
Offline OakeyDoak16v
Re: aaaaaaaaagh!
« Reply #6 on: 30 October 2008, 02:48 »
Neone??  :huh:
« Last Edit: 30 October 2008, 02:50 by OakeyDoak16v »
