Author Topic: radiator?  (Read 650 times)
Offline ben harcombe
radiator?
« on: 27 October 2008, 21:20 »
I'm wondering which vw's use the rad's with the fillercap on the side so i can get rid of the plastic exspansion tank
Re: radiator?
« Reply #1 on: 27 October 2008, 23:16 »
older rocco and mk1 tintops
Re: radiator?
« Reply #2 on: 27 October 2008, 23:26 »
are they available off the shelf still
are they straight swap on a 16v kr 89?
Re: radiator?
« Reply #3 on: 28 October 2008, 10:09 »
pretty sure you can still get them, will be a straight swap once you get the right rad hoses as a kr one is a bit narrower.  just make sure its a rad off a 1.8 model as they'll be a bit wider, which is what you'll need if fitting to a 16v!
