Author Topic: Lower cam belt cover  (Read 1166 times)
Offline hobbes
« on: 26 October 2008, 22:22 »
Hi, having trouble re-fitting the lower cam belt cover after changing the water pump.  for some reason i cannot get it to sit right and now the crank shaft pulley is rubbing on the plastic cover.  is there some special way i need to do this.
i did bend the metal plate somewhat to access the pump and i'm wondering if this is preventing it from sitting right....all tips gratefully received...
ps - is the plate required>?
Mk2 Golf GTI 16v
Mk4 Golf GT TDI
Offline Diamond Hell
  • Opinions я Us
Re: Lower cam belt cover
« Reply #1 on: 27 October 2008, 10:05 »
Wow - it's like a self-answering topic.  :grin:
The cambelt has guards on it for a reason - it's not the sort of thing you want contaminated with crap from the road.
Offline Conker
« Reply #2 on: 27 October 2008, 12:00 »
I thinks its an MOT fail too.
Just persevere with getting it re-shaped.
Offline hobbes
« Reply #3 on: 27 October 2008, 18:56 »
Sorry, i wasn't very clear - i would never not use the cam belt cover, i was referring to the tin plate that sits behind the oil pump pulley and partially in front of the water pump.  i've bent it which i think is causing the cam cover not to sit properly and therefore the crank pulley to rub.  anyway, problem solved - new plate from vw coming for £7 trade plus vat....
Mk2 Golf GTI 16v
Mk4 Golf GT TDI
Offline Mr Blue
« Reply #4 on: 27 October 2008, 20:05 »
i removed mine completely as i bent it. to the bin it went  :laugh:
