Author Topic: Dismantling Distributor  (Read 1430 times)
Offline Re-rewind
« on: 26 October 2008, 01:54 »
how do you do this on a Mk2 16v Gti distributor, believe its from the KR engine if that's any help but i think they;re all pretty similar
cheers
Offline mattkh
Re: Dismantling Distributor
« Reply #1 on: 26 October 2008, 20:46 »
Hi
Have you got it off the car yet.
Offline Conker
« Reply #2 on: 26 October 2008, 21:32 »
If you mean how do you literally take it apart, I found this very difficult and ended up buying a new one. The rotor arms that come attached to the new dizzy's often need crunching up with some pliers as they are glued on solid.
Offline wriggley
« Reply #3 on: 26 October 2008, 22:49 »
i took a dizzy of a audi 80 2.0l 16v at week end fiteed and works a treat cost me 5 quid from scrappy
Offline Re-rewind
« Reply #4 on: 26 October 2008, 23:43 »
No it needs to be taken apart, i have a part from inside one distributor that needs transferring to another and yes they are both off of the car
Offline mattkh
« Reply #5 on: 27 October 2008, 06:41 »
Hi
Any chance of a photo.
Apparently the vw rotor arms are glued on, so you literally smash the rotor to put a new rotor arm on.
Offline stokeballoon
« Reply #6 on: 27 October 2008, 07:25 »
There is a small pin that holds the drive on (the bit that sits on the cam).  Punch that out and the shaft will pull out.  You can also replace the Seals as well.
