did this a while ago so there may be the odd glitch but shoudl all be there. may do somethgin later to add a bit more detail clarity
here goes
labels wireign diagram for the ABF, stuff in green you won't need to do anythign with, that lot goes straigth from the ecu plug to ether the multiplug onthe enigne or various sensors around the engine the stuff in red boxes you'll need to do somethign with if compoent dosen't have box it is optional
pinout for the ecu, pin number function and wire colours
pinout for the engine multiplug usefull for megasquirt
the remaing wires and some info on connections sensors need
the immob box
that lot should help you sort through loom and find / correct and mistakes or faults, may do a guide on how to connect it into both pre and post 90 fuesboxes next time i do one
