Author Topic: Pros and Cons to using Mk3 gearbox in 2l conversion  (Read 1410 times)
Offline danj3000
« on: 24 October 2008, 18:53 »
Hi Guys,
I'm very seriously considering doing the 2l bottom end conversion to my 8v digifant. I now have access to a complete mk3 golf gti 8v to use all parts and wanted to know if A) The mk3 gearbox can be used, B) If there is any pros and cons in doing this?
By the way the donor mk3 in question is an 'R' reg so has the engine code AGG i believe?
Cheers  :smiley:
Offline Diamond Hell
  • Opinions я Us
Re: Pros and Cons to using Mk3 gearbox in 2l conversion
« Reply #1 on: 24 October 2008, 22:38 »
I don't think there are any downsides to what you're suggesting.  It's a stronger gearbox and clutch - bigger input shaft.
Offline danj3000
« Reply #2 on: 24 October 2008, 22:45 »
ok, are the gear ratios much different to the mk2 8v gearbox? at a guess i imagine the 5th gear would be fractionally longer?
If i were to do the 2l bottom end conversion and keep the mk3 gearbox, would i need to change anything to accommodate it such as mk3 clutch cable or slightly different gear linkages?
cheers
Offline danj3000
« Reply #3 on: 25 October 2008, 21:12 »
anyone have any idea?  help is much appreciated :smiley:
Offline danny_p
« Reply #4 on: 26 October 2008, 13:53 »
the 2.0  gear box is a direct swap for the mk2   except for the clutch.    you use a mk3 2.0 clutch as the input shaft is bigger on the gear box,  thats it the rest just bolts up as if it were a mk2 box
all the VW's have gone bar 1.
Offline danj3000
« Reply #5 on: 26 October 2008, 16:19 »
Thanks there danny_p.  :smiley:
Just another thing that would be useful to know is if the mk3 gearbox ratios are any different to the mk2's?
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
« Reply #6 on: 26 October 2008, 18:16 »
1st and 2nd are, 3rd 4th and 5th are taller..
clicky for info i wrote in my project  :wink:
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline danj3000
« Reply #7 on: 26 October 2008, 18:43 »
That was really helpful to read thanks,  :smiley:
Looks like it will be a good idea to use the box too then when i do the conversion.
« Reply #8 on: 27 October 2008, 16:49 »
MK3 box also works with MK2 16v gearbox.  the gearbox is NOT any stronger however, the internals are made of the same grade of stilton.  Yes the input shaft is bigger but that doesnt really amke any difference to the strength.  I.e. if you had enough torque to snap the input shaft the box would explode way before then.
as said main advantage is the slightly more relaxed ratios dfor cruising (could be seen as a disadvantage if sportyness is what you want) other advantage is it'll be a bit newer. Just make sure the reverse gear is ok, they tend to be a problem more on MK3s.
