he mentions k-jet abf, I assume MK2 16v KR managment?
if so advance is controlled by ign controler in scuttle area, which has a vac line to brake servo pipe plus rev counter signal and coolant temp, should be a hall sensopr plug on dizzy. Oh and make sure you put the right dizzy on it, abf one wont work you need kr or 9a. no knock sensing so you cant run it on pap fuel unless you back off nthe ign timing.
