Author Topic: Optimax to normal unleaded?  (Read 3439 times)
Offline Deefadog
  • Mk2 16V (November 89)
« on: 26 May 2004, 12:48 »
I just wondered, my new mk2 16v has been driven on Optimax by it's last owner and has no problems with it, I can't really afford Optimax and would rather use normal unleaded, what problems (if any) whould i encounter, any timming adjustments needed?
Thanks for any help
Offline gibby
Re:Optimax to normal unleaded?
« Reply #1 on: 26 May 2004, 12:57 »
There shouldn't need to be any adjustments at all, but if you can stretch to optimax I would do, I'm just about to start using it myself after using unleaded. From some of the threads I've seen on here it appears that the fuel consumption is better with optimax, so even though it cost more you should get more mpg so the cost should be negligable anyway, try it out for a couple of tank fulls and see how it goes.
......now officially dubless.
marcus123
« Reply #2 on: 26 May 2004, 13:15 »
mate, strech the extra pennies per litre to use optimax.
it makes sense to because youll recoup that back and more because of the petrol consmption.
you have obviously got a much loved golf because the previous owner used optimax,
dont scrimp a few pennies on such a vital thing for your car, its just not worth it in the long run.
i bet your car is running sweet?
u wanna keep it that way, use optimax! ;D
Offline Deefadog
« Reply #3 on: 26 May 2004, 14:54 »
Ok, I did not know about the better mpg, thanks - Optimax is that Shell?  will superunleaded from ASDA or Tesco work just as good?
Offline gibby
« Reply #4 on: 26 May 2004, 15:02 »
Aye, optimax is shell, don't even bother with the supermarket fuel as it's regurgetated treacle !  :)
« Last Edit: 26 May 2004, 15:02 by gibby »
marcus123
« Reply #5 on: 26 May 2004, 15:18 »
optimax is only shell mate ;)
the others wouldnt work as well :)
Offline Deefadog
« Reply #6 on: 26 May 2004, 22:45 »
shell here I go ;)
Offline Davs mk2 16v
« Reply #7 on: 26 May 2004, 23:08 »
i know its hard to use optimax when you see 2 pumps next to each other and theres a 9p difference between the two, but i try to think as the difference between otpitmax and regular like the difference between diesel and petrol.
marcus123
« Reply #8 on: 27 May 2004, 09:01 »
wise words,
optimax is the golf gti of petrol! :D
Offline Pike
« Reply #9 on: 27 May 2004, 12:31 »
I can't sing the praises of Optimax enough. I had the head of an engine that has done about 10 000 miles and has always been run on optimax (since its rebuild) and it was as clean as a whistle.
There is no substitute for high quality fuel.
Golf GTI Championship #4
2008 VW1 3rd
2009 VW1 3rd
