Golf mk2
wont start
Topic: wont start (Read 2570 times)
VeeDubGTI16v
Guest
wont start
26 May 2004, 12:12 »
my car wont start when the ignition is turned. the fuel pump charges up, but there is nothing going on when you turn the key to the start engine position. is this the ignition coils fault?
benjam_in
Here all the time
Re:wont start
26 May 2004, 12:36 »
when was the last time it started?
Golf Mk2 Gti 1988
VeeDubGTI16v
Guest
Re:wont start
26 May 2004, 12:45 »
last night.
i thought it might be the barrell come loose cos i changed it but thats ok, im thinking its the coil cos i listen to the radio with the ignition engine off quite a bit and a mate burnt is coil doing this.
its nothing to do with battery/alternator
Blue MK2
Guest
Re:wont start
26 May 2004, 15:04 »
does it turn over?
i dont think its the coil.
I used run on a rubbish battery and after a few minutes of audio play, the car would not even turn over.
Try jump starting it first
VeeDubGTI16v
Guest
Re:wont start
26 May 2004, 15:30 »
it wont jump start :'(
the battery is good
Blue MK2
Guest
Re:wont start
26 May 2004, 15:34 »
how do you mean exactly mate? does the engine turn and not fire, or does it not turn at all?
VeeDubGTI16v
Guest
Re:wont start
Reply #6 on:
26 May 2004, 16:01 »
ok i have multimetered everything and theres no power getting to the starter motor. so its either the ignition switch or the wire.
VeeDubGTI16v
Guest
Re:wont start
Reply #7 on:
26 May 2004, 16:21 »
anyone know how to get the ignition switch out?? i have got the lock barrell out, does it push out the back of the housing?
Last Edit: 26 May 2004, 16:22 by veedubgti16v
VeeDubGTI16v
Guest
Re:wont start
Reply #8 on:
26 May 2004, 17:04 »
ok sorted now.
it turned out to be the lock barrel itself
the end bit which turns the ignition switch was worn!!!! its only abpout 4 months old!!! oh and if you havent guessed i bought the lock set from gsf
its got the patern lock with the original veedub barrel now
Golf mk2
wont start
