Author Topic: Lowering mk4's serious stress on components  (Read 2817 times)
Offline shaft69
« on: 22 October 2008, 23:11 »
I've lowered my car on coilovers found that wishbone bushes are split. The thing is arms are only 6 months old and when looking at arms they look under serious stress pointing upwards. thinking about poly bushes but way arms look poly bushes would drop out. Anyone had probs with lowering there cars. mine's dropped about 60-70mm all round.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline richw911
Re: Lowering mk4's serious stress on components
« Reply #1 on: 22 October 2008, 23:26 »
Wind it up to a 40mm drop IMO
Offline iMation
  • G SiXtY
« Reply #2 on: 23 October 2008, 08:08 »
ive got mine on its arse at the mo, ive found that the Audi TT wishbones are working a treat tbh, not had a problem with them, the only problem i have now is, not having front and rear ARB's :D
Stu
p.s. when i stuck me coilovers on i changed all bushes and shock asorbers
Meh....
Offline dai-cymru
  • 1989 MK2 16V
« Reply #3 on: 23 October 2008, 12:32 »
lowering causes stress on componets because of altered geometry the only way to avoid it is to raise it closer to standard, large wheels also cause problems to bearings and bushes, upgrading the bushes will help but where does the stress go then?? through metal components and cracks are possible, but thats is unlikely unless it's seriously low and you have massive wheels
Offline iMation
  • G SiXtY
« Reply #4 on: 23 October 2008, 13:22 »
this is why you get AIR Susspension, so then when your ROLLIN you can raise up :D:D:D
Meh....
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #5 on: 23 October 2008, 19:05 »
Do you mean heavier wheels??  'Coz, the 18" Superleg's I've just bought are lighter than the 16" Brands Hatch rims I've just taken off!! :smug:
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline richw911
« Reply #6 on: 23 October 2008, 19:22 »
oooh pics....... :wink:
Offline Hulmie
  • White MK4 1.8T AGU K03s
« Reply #7 on: 23 October 2008, 19:37 »
Stu
Audi TT wishbone's? or do you mean Audi TT front arm rear bushes? If Audi TT arms fit then i may go that way.
Offline dai-cymru
  • 1989 MK2 16V
« Reply #8 on: 23 October 2008, 19:47 »
nothing to do with the weight its the width thats the problem  :smug:
Offline shaft69
« Reply #9 on: 23 October 2008, 21:56 »
I spoke to balance motorsport he said betsway round it was to fit everything thing from audi tt if lowering 50+. What would car drive like if arb removed, they don't fit one to mk2 driver only gti. My old mk2 driver was on Jreg with 2.1lt tsr engine in and had no arb. lowered 40mm that drove well. will get pics up tomorrow take some in morning when get car on ramp.
184 Wallgate, Wigan
WN3 4AL
07966492823.
