Author Topic: Wax????  (Read 4050 times)
Offline ace
Wax????
« on: 20 October 2008, 13:15 »
how often should u apply wax??? should it be everytime u polish or only every so often???
also what is the best wax for black cars? used the meguirs 3 step wax, but wasnt overly impressed with it
thanks
Offline Organisys
  • Old and Slow...
Re: Wax????
« Reply #1 on: 20 October 2008, 13:18 »
After polishing yes, as when you are polishing you are removing any wax.
Wax is a personal preference, but try the purple dodo Juice or the newer Autoglym designed for modern / darker paints.
Offline Guy
Re: Wax????
« Reply #2 on: 20 October 2008, 13:47 »
what organisys said... you need to keep your paint waxed in order to protect it... you don't however need to polish it every time you clean your car...
so spend time doing one proper clean, polish and wax every couple of months or so and in between you can just do a quick two bucket wash and go
also - have you clayed your car... this will drastically improve your results
wax is a personal thing... depends on what your budget is... collinite is a very good wax for the money
Offline ace
Re: Wax????
« Reply #3 on: 20 October 2008, 13:55 »
guy, i clayed the car about 6 weeks ago, made u huge difference to the car.
i tend to normally polish the car after i wash it. was using mer previously, but found it to be quite a hard polish and was chalky.
after i clayed the car, i used the meguirs 3 step and was impressed with the results (apart from the wax).
Offline Dan J
Re: Wax????
« Reply #4 on: 20 October 2008, 14:08 »
for easy on and off collinite 845 is very good and it protects your car for up to a year and to add a deep gloss on top of that i use dodojuice purple haze or poorboys nattys blue :wink:
Offline Guy
Re: Wax????
« Reply #5 on: 20 October 2008, 14:33 »
try a decent hard wax... you'll notice the difference between that and stage 3 of the megs...
Offline ace
Re: Wax????
« Reply #6 on: 20 October 2008, 14:38 »
gonna be a complete pain, but any which you can recommend???
Offline Guy
Re: Wax????
« Reply #7 on: 20 October 2008, 14:52 »
you're not being a pain
trouble is lots of people will recommend lots of things
my faves at the moment are
collinite 915 as a hard general purpose wax
chemical guys 50/50 as a finishing wax
http://www.chemicalguysuk.com/Carnauba_PASTE_WAX_Limited_Edition_5050_Paste_Wax_p/50-fslash-50.htm
both of which provide very good results...  especially when combined with their respective sealants
depends on your budget...swissvax is very good stuff but pricey
dodo juice is good stuff too... good vfm
spend a bit and you will see the results... generally the higher the carnauba content the better the wax
Offline ace
Re: Wax????
« Reply #8 on: 20 October 2008, 15:17 »
cheers guy, will have a good look around after work.
