Author Topic: What size spline?  (Read 1620 times)
Offline dubsport
  • TDI POWAR!
What size spline?
« on: 18 October 2008, 20:13 »
have an 89 8v gti ... will the spline for the steering wheel be big or small?
thanks :afro:
Offline Khare
  • The bear that khares
Re: What size spline?
« Reply #1 on: 18 October 2008, 20:15 »
if the hazard switch is on the dash it will be small, if its on the steering column, it will be a big spline.
being 89 its probably small.
Offline cняis
« Reply #2 on: 18 October 2008, 20:19 »
not necessarily true...
my 88 (F plate) project had older electrics (hazard on dash) but BIG spline.
take the steering wheel off and see if the end of the column has a splined ring like this:
^big spline
« Last Edit: 18 October 2008, 20:21 by cняis »
Offline Khare
« Reply #3 on: 18 October 2008, 20:23 »
 :undecided:
as a general rule it works like that. so i heard.
Which one is the spline then? the bit with the teeth?
Offline cняis
« Reply #4 on: 18 October 2008, 20:25 »
:undecided:
yes mate, just below the thread on the very end of the column (its what the steering wheel slots into). you can sometimes get the splined ring off which will turn your column into a small spline one, but i couldnt get mine off!
Offline dubsport
  • TDI POWAR!
« Reply #5 on: 18 October 2008, 20:27 »
ok after a bit of a search i THINK they were changed to big splines after 88 mine has the hazard on the steering colum, my car is an 89 but has the 90spec arches/big bumpers etc but i think it was registered in 1990 ... all very confusing lol
thanks for the replies il bid on this steering wheel then  :grin:
Offline cняis
« Reply #6 on: 18 October 2008, 20:38 »
dammit biatch im after a wheel too... hope we're not bidding on the same one!!
if you're hazard switch is on the column then id deffo say it was big spline.
edit: damn ive sodding missed the auction end!  :cry: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=260297747772&ssPageName=ADME:B:WNA:GB:1123
Offline dubsport
  • TDI POWAR!
« Reply #7 on: 18 October 2008, 20:41 »
not bidding on the same one fella ... but if we were i would have let you win :afro:  :grin:
« Reply #8 on: 20 October 2008, 10:02 »
yes the spline adaptors were fitted from somewhere in 88, my mates totally std 88 didnt have the spline adaptor, and my 89 F driver did.
