Author Topic: Where does this bolt on to?  (Read 1842 times)
Offline Steve_B
« on: 18 October 2008, 14:11 »
Was working on the engine and found this just hanging loose:
Looks like the bracket has rusted away. Where is it meant to bolt on to and what's this part called? Or can I get around using it somehow?
Steve
Offline Chris-White
  • Manufactured in Germany. Ruined in Britain.
Re: Where does this bolt on to?
« Reply #1 on: 18 October 2008, 14:31 »
bolts on to the exhaust manifold. the other end of the pipe goes to the airbox, its for hot air when running in the winter.
Ive never had a mk2 with one of these fitted (pipe usually dies) so cant say it make alot of difference personally.
Offline Dolly
« Reply #2 on: 18 October 2008, 16:57 »
made a hell of a difference running my driver a few winters ago, dont think the Gti models need it really
Offline Gloves88
« Reply #3 on: 18 October 2008, 18:00 »
Just disconnect the hose, you dont need them on GTi's
VeeDubGTI16v
« Reply #4 on: 18 October 2008, 18:32 »
block up the hole on the air box as well!
Offline danny_p
« Reply #5 on: 18 October 2008, 18:59 »
may as well pull the trumpet out the air box while your at it
all the VW's have gone bar 1.
Offline cняis
« Reply #6 on: 18 October 2008, 20:23 »
and drill lots of holes into the wing side and front of the air box lower half  :smiley:
Offline Mr Blue
« Reply #7 on: 18 October 2008, 20:55 »
dont botherd blocking the hole. Yep havnt noticed any diffrence without this pipe. Bolts over the zorst manifold as said.
my 8v digi doesnt have this trumpet thing in the airbox :huh:
Offline cняis
« Reply #8 on: 18 October 2008, 21:12 »
both of mine had it. it protrudes from the airbox to the rear drivers headlamp back plate. with a bit of a tug it will come out make the hole in the front of airbox a lot bigger  :smiley:
Offline Mr Blue
« Reply #9 on: 18 October 2008, 21:14 »
ahhhh that gay thing. Binned that! Thought it was something inside the airbox.
thanks :smiley:
