Author Topic: Stubborn caliper bolt  (Read 1949 times)
Offline nikkyboy
« on: 16 October 2008, 22:24 »
I'm having trouble with a seized top caliper bolt on my 8valve.  Managed to get the bottom one out, but the top one's rounded.
I've tried:
loads of penetrant spray
mole grips - grips evetually give in, slipping off and take chunks out of the bolt
filing the outside edges so I can hammer on a 12mm impact socket - the socket doesn't grip as much as whats seized the bolt, and slides off
hitting it with a hammer (probably wouldn't do much but made me feel better :grin:)
I'm stumped...any ideas?
Offline Dolly
Re: Stubborn caliper bolt
« Reply #1 on: 16 October 2008, 22:32 »
i got a set of irwin bolt/nut extractors knock the tightest fitting one over the bolts and as it turns it grips. i could believe how well these worked on various exhaust bolts ect.
http://shop.ebay.co.uk/?_from=R40&_trksid=m38.l1313&_nkw=irwin+extractor
Offline nikkyboy
« Reply #2 on: 16 October 2008, 22:42 »
they look the business and my local screwfix sell them. I'll give it a try tomorrow and let you know how I get on. Thanks for your help!  :smiley:
Offline Jay
  • balding fat cvnt
« Reply #3 on: 16 October 2008, 22:48 »
If that fails, Angle Grinder comes to mind  :evil:
Offline Mr Blue
« Reply #4 on: 16 October 2008, 22:49 »
get a blow torch and heat the bolt.
then smack a splined socket over the whole bolt and unscrew. Works well :smiley:
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #5 on: 17 October 2008, 00:11 »
Drill the head off the bolt, remove the caliper and then tackle the stud that remains, on a bench.
nige_s
« Reply #6 on: 17 October 2008, 13:21 »
A Dremel is your friend, great tools for cutting stubborn nuts and bolts of.  Less dramatic than an angle grinder and ideal for tight spaces.
Offline richard s
« Reply #7 on: 17 October 2008, 19:48 »
get some irwins they dont mess about
Offline nikkyboy
« Reply #8 on: 17 October 2008, 20:33 »
The irwins did it, took next to no effort, can't believe it!  Thanks all for the advice  :smiley:
Offline Dolly
« Reply #9 on: 17 October 2008, 21:21 »
good aint they  :wink:
