Author Topic: can i have some help?  (Read 1768 times)
Offline aj_golf
« on: 16 October 2008, 21:28 »
ok its all gone wrong this week
first my brakes wer all over the place so i tightened them up an tightened the wheel baring nut up ( just replaced beakes, wheel barings etc.) anyway.... think the balancing needs doing on my car ......
thats not the bite in the arse
went out init today running fine... put some petrol init went to the bank runnin fine
then its started playin up... pulled off from the lights an it cut out...started agen pulled off an started judderein
if you pull off nice an slow its ok but you exellerate abit its started judderin an it wont stop
its does it thru every gear
but if your not in gear you can rev the bolox off it an its sweet
an then this is what shocked me the most..
i went to work an left the car at home an my dad had a look and there was nothing wrong with it
he took it out an it was runnin sweet
im reali stumped  :undecided:
can i have some advice?
Offline Jay
  • balding fat cvnt
Re: can i have some help?
« Reply #1 on: 16 October 2008, 21:32 »
Dirty fuel? Blocked vacuum pipe that got unblocked eventually?
It it ain't still happening, don't worry  :grin:
Offline Khare
  • The bear that khares
« Reply #2 on: 16 October 2008, 21:38 »
i had this a month back, and it was cos it was running very rich. Get the emmisions tested, and tune to factory spec.
Offline aj_golf
« Reply #3 on: 16 October 2008, 21:44 »
wel i thought it was sh!t fuel cuz ive always had problem with bp fuel...it messed up my old car
i had a petol leak on the injector rail so i think there might be sum trapped air in there knockin about
could it be that?
Offline TheRaven
  • "I am female, I think the boobs are a giveaway..."
« Reply #4 on: 17 October 2008, 12:42 »
Hey check this out, its sound the same as mine?
http://www.golfgtiforum.co.uk/index.php?topic=95010.0
Professional Freelance Equestrian Photographer
www.ravenphotography.co.uk
www.ravenphotography.uk
Offline Organisys
  • Old and Slow...
« Reply #5 on: 17 October 2008, 12:43 »
what engine is it?
Offline Mew
« Reply #6 on: 17 October 2008, 12:45 »
could it be that?
8v digi? :undecided:
Offline Organisys
  • Old and Slow...
« Reply #7 on: 17 October 2008, 12:51 »
Ah right, refer to the RJ tune up guide and check all earth connections. Then check the fuel pump.
Does the fuel pump prime (hear it?) when you turn the ignition to 2?
« Last Edit: 17 October 2008, 13:51 by Organisys »
« Reply #8 on: 17 October 2008, 13:45 »
^^ if that checks out, pull the electrical plug off the main pump under the car and repeat the test.  if you dont hear the in-tank pump prime that would be the problem!
but fix the fuel rail leak before you do anything else, often the ends get all cracked.  just chop a cm or so off the line and refit :)
Offline aj_golf
« Reply #9 on: 17 October 2008, 15:11 »
ye its a 1.8 8v gti...thinks its a digi?
wel its not doin its any more
i can hear the fuel pump prime its all sounds ok
i think it was sh!t fuel but il run some injector cleaner through it just to be on the safe side
thanks for your help
