Author Topic: Changing interior - Side Air bags?  (Read 1861 times)
Offline billy_vw
« on: 16 October 2008, 20:48 »
Im gonna fit Recaro's into the GT TDi ive just purchased.
My question is , do i have to be careful on removing front seats as they are fitted with Side airbags?
Any help appreciated  :wink:
MK5 GT TDi
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: Changing interior - Side Air bags?
« Reply #1 on: 16 October 2008, 21:25 »
I'm sure there are some guides somewhere - I'd imagine disconnecting the battery first for 10-15 mins would be a good start! :afro:
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline richw911
« Reply #2 on: 16 October 2008, 21:27 »
Offline Rhyso
« Reply #3 on: 16 October 2008, 21:41 »
yep - disconnect the battery and go make a cup of tea before doing anything
you'll avoid fault codes that :afro:
Offline billy_vw
« Reply #4 on: 17 October 2008, 08:31 »
thanks again for your help :wink:
MK5 GT TDi
Offline Rhyso
« Reply #5 on: 17 October 2008, 08:35 »
i assume the Recaro's you're fitting have side airbags??
you may also find the plugs are slightly different too
Offline billy_vw
« Reply #6 on: 17 October 2008, 08:58 »
ill be fitting these
http://www.golfgtiforum.co.uk/index.php?topic=93829.0
hopefully plug and play
MK5 GT TDi
Offline Rhyso
« Reply #7 on: 17 October 2008, 09:01 »
if they are from the same year of Golf then yes they should be - for some reason VW changed the style of plugs on the seats at some point  :undecided:
Offline billy_vw
« Reply #8 on: 17 October 2008, 09:04 »
Ive yet to pick these up, but they have the same material pattern on both seats, so hope they do fit with no problems.
MK5 GT TDi
Offline Rhyso
« Reply #9 on: 17 October 2008, 09:06 »
worst case is you have to solder new plugs onto the seats
let us know how you get on  :smiley:
