Author Topic: Any mechanically minded people?  (Read 5132 times)
Offline DarnPB
  • Formerly Darnpistonbroke
Re: Any mechanically minded people?
« Reply #20 on: 16 October 2008, 19:27 »
If it runs ok on a run, but just cuts out or loses power when accelerating or pulling away, I would suspect the accelerator pump is getting lazy. This is either a mechanical or vacuum operated little pump within the carb that injects neat fuel into the throat of the venturi to prevent a lean cut during heavy throttle applications. A carb repair kit should have the parts included to repair this.
But get the ignition timing checked first.
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #21 on: 16 October 2008, 19:43 »
Errrr doesn't this sound like the old waxstat problem.......
Tom
Offline TheRaven
  • "I am female, I think the boobs are a giveaway..."
« Reply #22 on: 17 October 2008, 08:48 »
Tom
Dare I ask what this is?
Professional Freelance Equestrian Photographer
www.ravenphotography.co.uk
www.ravenphotography.uk
Offline Horney
« Reply #23 on: 17 October 2008, 09:23 »
Offline TheRaven
« Reply #24 on: 17 October 2008, 11:32 »
Tom
Have checked this out, the choke and everything is working fine!!
But guys... this is the strange thing, had the bonnet up last night and it was ticking over, sprayed WD40 into the top of the carb a few times and it was sweet as a nut for a few mins.
Did this a few times, went for a drive and it was no different, however, drove her to work this morning and she was brill!!!
Any ideas?
Offline tobz.
« Reply #25 on: 17 October 2008, 11:58 »
Tom
I dont think the pierburg 2E3 as fitted to the 1.3 has the waxstat, it's just part of the 2E2 as found on the 1.6
Raven, regardless of whether the carb is in good order or not I would thoroughly recommend you to try and find a weber to fit. I slapped one on my 1.3 rat hack and even with 190k on the clock it runs like a dream. Always idles perfectly regardless of temperature, has never cutout and it's made it reasonably quick. Combine a weber with a thorough service and I think you'll be laughing.
The carb you need is a weber 32dmtr which is unfortunately obsolete now so it's time to scour ebay and the forums. Occasionally a new old stock one will come up on ebay but be prepared to pay a lot of money. I got my secondhand one off a user on this forum for £50ish (can't remember).
Good luck
Edit: here ya go this one might still be available:
http://www.golfgtiforum.co.uk/index.php?topic=92548.0
« Last Edit: 17 October 2008, 12:01 by tobz. »
You got any pics of your dad's split ?
Offline Jay
  • balding fat cvnt
« Reply #26 on: 17 October 2008, 12:17 »
Webers are over rated for what you pay for them.
I've not had much trouble with my Pierburg carb, on the RARE occasion the car takes 2 or 3 times to start when it's absolutely f**king cold.
Offline TheRaven
« Reply #27 on: 17 October 2008, 12:28 »
See mine starts everysingle time, no matter what!
Just loses power at low revs?
« Reply #28 on: 17 October 2008, 13:48 »
get a tin of carb cl,eaner and spray that into the top of the carb, wd40 is next to useless at cleaning anything.
could it be carb icing, is the warm air pipe present and connected to the metal shroud on the manifold, and does the warm airt flap in the airbox open when engine is running?
Offline TheRaven
« Reply #29 on: 17 October 2008, 14:01 »
yea, everything like that is in working order, Im thinking it might just be some this working its way around the engine?
