Author Topic: Any mechanically minded people?  (Read 5130 times)
Offline Chris-White
  • Manufactured in Germany. Ruined in Britain.
Re: Any mechanically minded people?
« Reply #10 on: 16 October 2008, 12:22 »
still running a piersh!t carb?
Offline Horney
« Reply #11 on: 16 October 2008, 12:22 »
£50 sounds good.
For a tune up they should be checking the timing against factory spec which is adjusting when the spark plugs fire. Too early or too late cause rough running and idle problems or in the extreme melted engine components. He should be doing this with a timing strobe gun and following the way VW recomend you do it (Not sure if these carb engines have any quirks when timing them.) He should then sick a tester up your exhuast and measure the co2 output and adjust the ratio of fuel to air on the carb so that the engine is getting the optimum mixture.
For a service they should do what I listed in one of the posts above.
Nick
Offline TheRaven
  • "I am female, I think the boobs are a giveaway..."
« Reply #12 on: 16 October 2008, 12:23 »
Yea that sounds like it, his actuall words were *weve washed the jets through*
??  :undecided:
Professional Freelance Equestrian Photographer
www.ravenphotography.co.uk
www.ravenphotography.uk
Offline Chris-White
« Reply #13 on: 16 October 2008, 12:24 »
??  :undecided:
That'll be carb jets then i would have thought?
Offline Horney
« Reply #14 on: 16 October 2008, 12:24 »
That sounds more like they cleaned the carb jets out.
Edit: Damn you chris and your lightening reply skills!
Nick
Offline TheRaven
« Reply #15 on: 16 October 2008, 12:29 »
Right OK, now I will get this guy to come and service it, put some redex in it.
By the way I have no idea what carb it is, although it is the original? Does that mean anything to you?
I know the polos, golf and jettas of that era had sh!tty outsourced carbs made and fitted.
But the guy at the garage said the carb is fine?
Offline daniel-1986
« Reply #16 on: 16 October 2008, 12:33 »
i had a problem similar with my 1.3, check the auto choke fuse (no.17), its the one place no-one ever checks first always looking for the big problems first
Offline TheRaven
« Reply #17 on: 16 October 2008, 12:39 »
Ok, so where is this and how do I do it?
Offline Jay
  • balding fat cvnt
« Reply #18 on: 16 October 2008, 12:39 »
Putting Redex in is easy peasy as putting fuel in  :grin: Next time you FILL your tank put in the recommended amount of Redex in, which is usually 1/2 bottle to a FULL tank if it's the 250ml bottle.
Also try running Tesco 99 ron through, when I use that it makes my car so nice and steady and does not feel 'jumpy' when crawling at 1mph
You probably still have the Pierburg car fitted, they are apparently really bad  :rolleyes: People replace them with the weber carbs
Offline Agreeable Slick
  • Unit
« Reply #19 on: 16 October 2008, 12:41 »
Don't double post. ta
Edit: Sorry for the delay, some of us have to work for a living  :wink:
« Last Edit: 16 October 2008, 17:16 by Agreeable Slick »
