Author Topic: any one tried this ???  (Read 2450 times)
Offline sidecarphil
« on: 16 October 2008, 08:58 »
http://cgi.ebay.co.uk/VW-GOLF-MK2-MANIFOLD-1-8-2-0-8V-G60-STAINLESS-STEEL_W0QQitemZ170271512980QQihZ007QQcategoryZ38786QQtcZphotoQQcmdZViewItemQQ_trksidZp1713.m153.l1262
i know a lot of you have their coilover's but i wondered if there manifold's were any good ????
my down pipe is blowing and it cost's 260 euro  :angry: cos it has a cat in it  :angry: :angry:
Offline sidecarphil
Re: any one tried this ???
« Reply #1 on: 16 October 2008, 12:25 »
any one ???
if not do you recomend a 4 branch from any where else ??
Offline Mew
« Reply #2 on: 16 October 2008, 12:48 »
I've read about issues with power steering on the raceland manifolds, but that might just be for rhd in which case i guess you'd be ok!
Offline Organisys
  • Old and Slow...
« Reply #3 on: 16 October 2008, 12:53 »
Hello,
I have one on my daily. The only problem on a RHD car is the downpipe runs close the bottom of the steering column shaft. I covered the boot over the UJ with heat proofing otherwise it may have got too hot. been running this now for around a year with no problems.
Since you are in Holland, I take it your car is LHD, so the fittment should be fine.
 :smiley:
Offline cняis
« Reply #4 on: 16 October 2008, 18:15 »
Hello,
 :smiley:
my 4 branch isnt heat wrapped and has caused no problems with the steering rack  :smiley:
and thats over 30k miles  :smiley:
Offline sidecarphil
« Reply #5 on: 16 October 2008, 18:22 »
ok cool did you notice any power gain's ???
and how hard are they to fit ??? do you need the subframe off to fit it ?? i understand that you dont need it off to remove the down pipe but the 4 branch is bigger  :shocked:
« Last Edit: 16 October 2008, 18:24 by sidecarphil »
Offline cняis
« Reply #6 on: 16 October 2008, 20:31 »
it was fitted before i owned the car, so i cant say how difficult it is to fit or if there were any power gains  :tongue:
also i havent driven another GTI so i have nothing to compare the current GTI's power to.  :sad:
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
« Reply #7 on: 16 October 2008, 20:35 »
When i fitted my manifold it just about squeezed over the rocker cover or did i remove it :undecided:??. either way it went in.
Offline Khare
  • The bear that khares
« Reply #8 on: 16 October 2008, 20:45 »
the problem with these is the flange at the end. iirc, you have to use a mk3 exhaust system for it to fit, as it wont cnnect to mk2 systems.
Offline sidecarphil
« Reply #9 on: 16 October 2008, 20:56 »
with the inlet manifold off  :undecided: :undecided:
will a MK3 exhaust fitt the car ?? and how much of the exhaust will i need or can fit ???
