Author Topic: Unburnt fuel.  (Read 1952 times)
Offline Rodriguez
Unburnt fuel.
« on: 15 October 2008, 20:05 »
Getting a petrol smell when cold and popping when warm.  CO level is at about 1.5 and idle is bang on.  MPG is brilliant too.  Exhaust is throaty (aren't all 8V's) but I know it has a slight blow from a joint.  I know you lot can piece this puzzle!
Also what's a reasonable price to pay for getting stem seals sorted.  I would have a crack myself ,but as its a daily, I can't be without it for the two weeks it would take for me to get my head off :laugh: although I'm only getting the smallest puff of smoke after a really long descent.
Offline danny_p
Re: Unburnt fuel.
« Reply #1 on: 15 October 2008, 20:21 »
poping is more than likely caused by the blow in the exhaust, air +  hot exhaust containg unburnt fuel = POP,    petoly smell probaly just it running rich on the cold start
all the VW's have gone bar 1.
Offline Organisys
  • Old and Slow...
Re: Unburnt fuel.
« Reply #2 on: 15 October 2008, 20:31 »
If it's a Digifant, replace the blue temp sender on the front of the block.
Offline Rodriguez
Re: Unburnt fuel.
« Reply #3 on: 15 October 2008, 20:42 »
Aaah.  That blue sensor rear its head again.  Tis the root of all evil :evil:
Offline Organisys
  • Old and Slow...
Re: Unburnt fuel.
« Reply #4 on: 15 October 2008, 21:09 »
Nah. The closed throttle switch on the bottom of the throttle body is the root of all evil.
At least the blue temp sender can be changed easy in 2 mins.
Re: Unburnt fuel.
« Reply #5 on: 16 October 2008, 09:45 »
how bad is the blow, this could throw off the co level?  also what is the HC level, if its high you have unburnt fuel being blown out the back from incomplete combustion due to it running lean.  Mine had all of your symptoms and thats what it was!
Offline Rodriguez
Re: Unburnt fuel.
« Reply #6 on: 16 October 2008, 20:55 »
 mmm good point.  Its not a big blow, but the popping did improve a little after I cranked the CO up.  Gonna replace the exhaust this weekend hopefully and do me vacs and bluey for good measure.  Is there any other symptoms of running lean????
Cheers for the tips boys and girls.
16v for show 8 for a pro :cool:
Offline Khare
  • The bear that khares
Re: Unburnt fuel.
« Reply #7 on: 16 October 2008, 21:06 »
the stem seals i was quoted £90 including a skim.
but i got hold of a valve spring compressor, and took me about 20 mins to remove all valves and seals off. Dont know about putting them in though, should be the same as taking them out so shouldnt be hard.
Offline kittie
Re: Unburnt fuel.
« Reply #8 on: 17 October 2008, 14:01 »
I've got popping too.... it's a digi, blue temp sender replaced, set up as per rubjonny's guide, new exhuast centre section the other day and rest of exhaust checked out ok, co2/idle set up at garage... still popping and (very) occasionally stalls when cool  :sad:
Offline Organisys
  • Old and Slow...
Re: Unburnt fuel.
« Reply #9 on: 17 October 2008, 14:04 »
Kittie, Was the blue temp sender new from VW?
If the co2 was done, this is strange, maybe the AFM ? RubJ?
