Author Topic: Coolant Draining  (Read 3392 times)
Offline MikeGTI...
Coolant Draining
« on: 15 October 2008, 19:39 »
Can anyone here advise on the best way to drain off and flush out/replace the engine coolant on a AUM engine?
Thanks
Mike
Offline richw911
Re: Coolant Draining
« Reply #1 on: 15 October 2008, 19:39 »
Plug on the bottom or the rad  :wink:
Offline MikeGTI...
« Reply #2 on: 15 October 2008, 19:48 »
Is there a plug on the bottom of the rad? If so where about is it?  Will I need to remove the splash guard to get proper access to this?
Cheers again
Mike
Offline richw911
« Reply #3 on: 15 October 2008, 19:52 »
Cheers again
Mike
Yep the lower front of the radiator IIRC you dont have to remove anything.
Go to VW and get some G12+ coolant to top up with about the same price as anywhere but it comes with anti corrosives in it :afro:
« Last Edit: 15 October 2008, 19:55 by richw911 »
Offline T_J_G
« Reply #4 on: 16 October 2008, 01:42 »
It's like a little tap TBH
Offline Matt_Mk4
« Reply #5 on: 16 October 2008, 08:18 »
Need to do this myself! Especially before the winter sets in!!
Offline MikeGTI...
« Reply #6 on: 16 October 2008, 17:04 »
Ok ive located the tap now, easyily do-able without taking any parts off.  Will drain it over the next few days me thinks.  Be interesting to know how much that stuff is from VW?  Also is it worth buying some coolant flush?  and run that in the system for 50 or so miles?
Mike
Offline richw911
« Reply #7 on: 16 October 2008, 21:05 »
Mike
IIRC it was £5 for 1.5L, Not worth buying flush IMO just run a hose through it.
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #8 on: 19 January 2009, 13:35 »
Does the tap at the bottom of the rad empty ALL 5 litres of coolant?
My car's come back from my gimp of a mates' garage with some kind of 'no frills' coolant in it! :angry:
« Last Edit: 19 January 2009, 13:38 by Ivor Mk4 Turbo »
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline dai-cymru
  • 1989 MK2 16V
« Reply #9 on: 19 January 2009, 13:43 »
no off the tap you only get about 2 litres it's awkward to drain it alll out on rhyso's i had to remove the oil cooler pipes too, on my aum and 2.0 i only got it all out by removing the rad pipes from the block
