Author Topic: Electric Mirrors auto dip  (Read 3838 times)
Offline rskardon
« on: 14 October 2008, 18:53 »
Hi there, i have the electric folding mirrors, i read that the mirror is supposed to auto dip when you select reverse with this addition, mine doesn't do this, is it possible to turn this on? Unfortunately i dont have the full size MFD so dont have the menu system,
Cheers,
R
« Last Edit: 14 October 2008, 19:04 by rskardon »
Offline 182_blue
Re: Electric Mirrors auto dip
« Reply #1 on: 14 October 2008, 18:58 »
is the Knob adjuster set for the front passenger mirror ?
Offline rskardon
« Reply #2 on: 14 October 2008, 19:06 »
The mirrors do move with the adjuster but i believe they are supposed to dip automatically if you have the folding mirrors?
Offline fantazia92
« Reply #3 on: 14 October 2008, 19:12 »
If the knob is in the passenger mirror adjustment position then it will dip when you select reverse.
WhiteGTI
« Reply #4 on: 14 October 2008, 19:14 »
182 is correct.....
If you position the wing mirror adjuster button and leave it on the passenger mirror (i.e. the indicator on the knob should be pointing to the bottom right, therefore meaning that it is positioned for adjusting the passenger mirror), then the mirror will dip once reverse is selected.
Offline 182_blue
« Reply #5 on: 14 October 2008, 19:15 »
as i said above mate, ps read the manual next time save me the job of doing it for you  :rolleyes:  :grin:
Offline bacillus
« Reply #6 on: 14 October 2008, 19:18 »
What year is your car as the kerb view option only appeared from MY2007 cars that had the lux pack or rear view sensors.
Without traction power is nothing!
Offline rskardon
« Reply #7 on: 14 October 2008, 19:19 »
I just went out and tried this and no luck unfortunatley, perhaps it has been disabled on mine for some reason, will check with the dealer when it is next in,
Thanks for the replies though,
R
Offline 182_blue
« Reply #8 on: 14 October 2008, 19:20 »
theres a point
Offline rskardon
« Reply #9 on: 14 October 2008, 19:20 »
That might be the issue! its an 05 car,
Thanks for the input!
