Author Topic: Getting my car running just right  (Read 2755 times)
Offline drivebycar
« on: 14 October 2008, 12:01 »
Hello!
So I started tuning my car last night a la rubjonnys guide.
First things first the idle is going up and down and up and down between 750 and 1000rpm, which makes it very hard to get the idle and co2 just right! Is this the ISV?
also while I was doing it, the CO2 screw didnt seem to make alot of difference when winding it in. I was winding it in to wait for the engine to sound rough, but never really got to that point, so was a bit clueless really as I didnt have alot to work with! Anyway I set it up and went for a drive, then it stalled when I put my foot down on the clutch. So re-adjusted the co2 and idle to make it run.
I know for a fact the dizzy has been advanced, so would that be causing these problems or is it likely to be something else? I am planning on putting the dizzy back to standard and checking the other timing tonight.
Thanks  :smiley:
Normal is getting dressed in clothes that you buy for work and driving through traffic in a car that you are still paying for - in order to get to the job you need to pay for the clothes and the car, and the house you leave vacant all day so you can afford to live in it.
Offline Conker
Re: Getting my car running just right
« Reply #1 on: 14 October 2008, 12:48 »
Did you disconnect the ISV circuit at the coil ?  (Red wire)
Offline drivebycar
« Reply #2 on: 14 October 2008, 13:30 »
No? Should I have done?
I was following rubjonnys guide.
« Reply #3 on: 14 October 2008, 15:24 »
Do you have an 8v or a 16v?  If 8v, check the idle switch. you should hear it click when the throttle is shut,  also check the wiring to it behind the throttle body it often snaps here.  This will cause the idle to be uneven and the car to stall occasionally when you dip the clutch.  Once thats sorted reset the ignition timing to the factory settings, set the idle back to 900 then see where that gets you on the CO front.
Offline drivebycar
« Reply #4 on: 14 October 2008, 16:09 »
Yeah it is an 8v. where abouts is the idle switch and what does it look like?
« Reply #5 on: 14 October 2008, 16:23 »
its underneath the throttle body, cant really get to it without taking the inlet boot off!
Offline drivebycar
« Reply #6 on: 14 October 2008, 16:33 »
How hard is that? Would I haveto take off the inlet manifold?
Offline Uruk Hai
« Reply #7 on: 14 October 2008, 16:35 »
No just the rubber boot.
Offline drivebycar
« Reply #8 on: 14 October 2008, 16:47 »
Ok so not that hard then  :laugh:
« Reply #9 on: 14 October 2008, 16:49 »
if you know the pointy end of a screwdriver from the blunt end no not hard  :grin:
