Author Topic: g2 2.0 stuttering badly around 90mph  (Read 1292 times)
Offline paultownsend
« on: 14 October 2008, 11:44 »
as above. an intermittant fault, but my 2.0 8v mk2 91'gti has started stuttering badly and totally looses power only in 5th gear around the said speed circa 4.5k (cant recall rpm)
in pulls as usual in every gear until it reaches that speed/rpm
iv checkes all connections, leads, vacume hoes etc and have a half tank of v.power. i just cant figure it out!  drove to my friends it happened (motorway) drove back it stopped
any help as usual chaps? [:)]
Offline Horney
Re: g2 2.0 stuttering badly around 90mph
« Reply #1 on: 14 October 2008, 11:46 »
Try a new set of leads as these things really hate leads that are not 100%.
Nick
Offline Simon8v91
« Reply #2 on: 14 October 2008, 11:48 »
Lift pump?  :smiley:
Offline Skiing
« Reply #3 on: 14 October 2008, 11:50 »
Mine did this before I replaced my lift pump too...
1988 Golf GTi Mk2 16v 2.0 9a bottom end- Oak Green - 3 door - full black factory leather...
« Reply #4 on: 14 October 2008, 12:48 »
lift pump you think?  did this only happen at high gears at high speeds?
how much we talking for the pump?
Offline Simon8v91
« Reply #5 on: 14 October 2008, 13:11 »
For me the symptom was a noisy main pump as air was bled into the system because the in-tank pump was not doing its job.
In your case I was trying to think what could effect fuel supply with an engine under load and a car moving at speed with half a tank of fuel.  I could be wrong  :undecided:
The pump is about £30 from GSF etc.  :smiley:
Offline danny_p
« Reply #6 on: 14 October 2008, 19:49 »
sounds like plugs /leads to me.   high speed in high gears is when the enigne is under prolonged load is where a spark related misfire is going to show most
all the VW's have gone bar 1.
« Reply #7 on: 14 October 2008, 23:56 »
i havent been using the car as much recently and is now parked outside. left for 2 days max without use. perhaps the weather setting in also?
the plugs and leads, dizzy and arm/cap were all changed with the conversion < 4 months ago and all vw items.
surely if it were fuel starvation from pump in would be apparent in 3rd and 4th at high revs?  and with the big valve hesd ita allways at 6k!
Offline danny_p
« Reply #8 on: 15 October 2008, 20:48 »
fuel starvation can do that,   if the main pump sits in what chould almost be called a littel tank so it can push you allong on that for a while  but when cruseing you'll be useing fuel from around pump faster than its arriveing > problem
that chould be it but its still worth checking plugs
