Author Topic: Spark plugs for mk5 GTi  (Read 3468 times)
Offline Saint Steve
« on: 14 October 2008, 07:25 »
Has anyone replaced these?, and does anyone know roughly how much these are?
Mines due in for service in 2 weeks time, and its done 23-24k miles.Do they normally replace them on this service or is it worth getting them
to replace them if they are cheap enough.I know its normally brake fluid change aswell on a 2 year service.
Cheers peeps.
Offline CocoPops
Re: Spark plugs for mk5 GTi
« Reply #1 on: 14 October 2008, 07:53 »
Don't they use platinum tipped ones good for 60k now?
2018 GTI Performance Pack DSG 5dr, Tornado Red, Leather, 18" Seville Wheels, DCC Suspension, Tints, RVC
2018 Lotus Elise Sport220
Previous : 1983 Mk1 Golf 1.1 & 2008 Mk5 Golf GTI Ed30
Offline bacillus
« Reply #2 on: 14 October 2008, 08:05 »
iirc they were around £9 each from VW.
Without traction power is nothing!
Offline Saint Steve
« Reply #3 on: 14 October 2008, 12:03 »
is it easy to replace the plugs or have you gota strip half the top of the engine to get to them??
Offline bacillus
« Reply #4 on: 14 October 2008, 14:52 »
It's not really difficult!
Provided you manage to remove the engine cover in one piece :wink: then you should be able to remove the coil packs without too much difficulty to get to the plugs.
http://www.golfmkv.net/blog/archives/9
Offline Saint Steve
« Reply #5 on: 14 October 2008, 17:47 »
Is there any benefit replacing them after 24k when to me a spark plug used to be changed annually. Are they made of some super strong
plating??. Is it not worth doing untill 60k?
« Last Edit: 14 October 2008, 19:14 by Phil Mcavity »
Offline bacillus
« Reply #6 on: 14 October 2008, 18:04 »
RedRobin had a misfire problem or something similiar with his car around 40k miles that was eventually diagnosed as bad plugs. He now intends to change his at 20k.
fwiw I change mine at every yearly service interval and I'm a low milage driver.
Offline RedRobin
« Reply #7 on: 14 October 2008, 19:06 »
....On JKM's advice, a remapped car is more likely to benefit from more frequent plug changes. Also, their advice was that the GTI's stock plugs were totally adequate.
The misfire was diagnosed and solved very quickly (not "eventually") thanks to JKM, and I will now change every 20k miles as preventative maintenance.
:afro:
Offline mrlapou
  • Mean GTi
« Reply #8 on: 16 October 2008, 09:50 »
If changed regularly, this helps avoid them being seized in the hole.
Dead easy to change. Should take about 40mins. Need a long reach narrow socket with a rubber holder in the end which hooks onto the end the plug to help pull them out when slack.
Not having proper spark plug socket. I used a std long reach box spanner and a long reach grabber device. Worked just a treat.
Bought plugs from GSF.
