Author Topic: IS IT BROKE???  (Read 2692 times)
Offline golf on 20s
IS IT BROKE???
« on: 23 May 2004, 14:57 »
i was fitting my amps and subs in my mk1 cab yesterday, everything went in no hassle at all, everything worked fine. but when i disconected my battery, then connected it, i reset the clock on the mfa, however when i was cruising around town i noticed that the clock wasnt at the right time and the mfa speedo said inwas doing 191mph?? any one got any ideas?  ive already tried reseting the mfa but still no joy?
Offline SoundillusioN
Re:IS IT BROKE???
« Reply #1 on: 23 May 2004, 15:07 »
MFA units have a tendency to lock up when its power supply has been messed with.  They're usually upset just by taking the + off the battery then putting back on with it sparking in ya hand.  Disconnect the earth on the battery and leave off for 2 or 3 mins.  Put it back on and all should be well.  If not, tell us.  ;)
Offline AdamB
  • The Perfect Storm
Re:IS IT BROKE???
« Reply #2 on: 23 May 2004, 15:36 »
ithe mfa speedo said inwas doing 191mph?? any one got any ideas?
Quite obviously you have a very fast cab indeed
I don't own this anymore - I just can't be arsed to change the picture
Re:IS IT BROKE???
« Reply #3 on: 23 May 2004, 15:56 »
The Mfa shows you ur average mph from the last time it was last reset, this guy must fly!  ::) XJ220 conversion?
Offline vixteris
Re:IS IT BROKE???
« Reply #4 on: 23 May 2004, 15:57 »
i took out the fuse and it reset mine - maybe just lucky but worth a try  ;)
Re:IS IT BROKE???
« Reply #5 on: 23 May 2004, 16:29 »
Nah, not lucky, that works just as well.  It's just I can never b bothered to find the correct fuse!
Offline golf on 20s
Re:IS IT BROKE???
« Reply #6 on: 23 May 2004, 17:15 »
cheers guys, much appreciated, it is fast just not that fast!!!! if only eh? ;)
Re:IS IT BROKE???
« Reply #7 on: 23 May 2004, 17:36 »
If it was that fast u'd need a chin spoiler extension of about 6 foot to keep her on the ground!  :o
Offline carrie
  • i can see into your soul and its not good
Re:IS IT BROKE???
« Reply #8 on: 23 May 2004, 19:20 »
or a vauxhall nova soundillusion ;) ;)
SAY YOU LOVE SATIN?, NO SATAN, ITS SATAN
Re:IS IT BROKE???
« Reply #9 on: 23 May 2004, 21:41 »
Nah, they should be 6 feet underground!  ;D
