Author Topic: MK2 5 Door Roof Lining  (Read 3286 times)
Offline Martz
« on: 13 October 2008, 14:27 »
Any ideas how difficult this is to replace? Looks a bit awkward!
Martz :cool:
Offline ...joe
Re: MK2 5 Door Roof Lining
« Reply #1 on: 13 October 2008, 19:51 »
easy! hardest part is finding a good one to replace it with!
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline Martz
« Reply #2 on: 13 October 2008, 20:05 »
And failing that? Can the old one be made good?
Offline ...joe
« Reply #3 on: 13 October 2008, 20:55 »
whats up with it? cracked or droopy?
Offline Organisys
  • Old and Slow...
« Reply #4 on: 13 October 2008, 20:58 »
Mines was droopy ~(no jokes) Staple gun did the job Joe! Was offered a mint 3 door one today, are they very different? just a little missing for the rear door apertures?
Offline Martz
« Reply #5 on: 13 October 2008, 20:59 »
The lining is all saggy.
Offline bomp
« Reply #6 on: 16 October 2008, 17:22 »
There's a black 5 door one with sunroof on the bay atm. 5 and 3 door are different because of the change in chassis shape for the rear doors, rubjonny can enlighten on this.
Life is like a skid mark on a toilet bowl.  Sooner or later someone\\\'s going to pi$$ you off.
Offline Jay
  • balding fat cvnt
« Reply #7 on: 16 October 2008, 18:26 »
I also need to sort mine out, what was the name of the glue you suggested Joe? I think the post in the MK2 section about this got lost because of the ground hog  :rolleyes:
Mine's all droopy and just needs glueing back up. I've got loads of no more nails but I think that's a bit extreme  :lipsrsealed:
Offline ...joe
« Reply #8 on: 16 October 2008, 19:29 »
the problem when they go saggy is that the thin layer of foam between the vinyl and the actual headlining degrades over time and thats why they go saggy. if you glue it up again you're glueing to the crappy foam again so ideally you need to strip the foam off and glue to a good surface. obviously this is a lot of work and you can cause more damage doing so.
you want a high temperature resistant impact adhesive.
sharpie
« Reply #9 on: 16 October 2008, 19:33 »
as above i'd be inclined to leave it in place. removed the roof lining from my previous golf and it's a fragile thing and easily bends/breaks while out the car.
