Author Topic: Steering Column Lower Bearing  (Read 5665 times)
Offline GOLF_MK
« on: 12 October 2008, 11:42 »
The golf went through it's MOT yesterday  :smiley: (first time pass) with three advisories;
Rear brake pipes (both sides) slightly corroded and play in steering column lower bearing.
I was aware of the play in the steering column but haven't looked at the cause yet so it's good to get a free diagnosis!!
Question is how easy is it to do?  Anyone here done it.  It's not urgent but will need doing before the next MOT i guess....
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: Steering Column Lower Bearing
« Reply #1 on: 12 October 2008, 11:46 »
All i know is on the MK3 its a bit of a pain but possible when you put your mind to it.  my top bearing is going.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline GOLF_MK
« Reply #2 on: 13 October 2008, 22:39 »
mmmm, nobody done it ever??  :shocked:
« Reply #3 on: 13 October 2008, 23:58 »
Having replaced my inner column a month or so ago I can 100% confirm that there is no lower bearing as such, however the top bearing is a roller type, the only bearing towards the bottom is a uj which would be easy to change.
Offline GOLF_MK
« Reply #4 on: 14 October 2008, 10:31 »
OK that's good info thanks.
I thought the movement felt like it was more at the top end to be honest so was surprised to get an advisory on the bottom bearing.  I think further investigations are needed.  Hopefully it's not the UJ £££ !!
« Reply #5 on: 14 October 2008, 11:14 »
My old column had play and was noted on the mot as the top bearing, I cured mine with replacing the column due to the steering lock playing up.
Offline leegt5
« Reply #6 on: 15 October 2008, 15:21 »
Theres is a lower column bearing/bush I have done mine !!! Its grey in colour and about £3 from volkswagen !! Not really common for them to fail, I just changed mine to eliminate it from being the problem !!
If you look at the bottom of the steering column there is a small spring butted up against the UJ. If you undo the UJ and the spring pops off there in a plastic bearing butted up inside the column tube.
If you look at the bottom of the steering column where the tube starts you can just see the silver rim of the lower column bearing. To remove it you lift the inner column out then put your finger up the bottom of the tube and pull it out.
« Last Edit: 15 October 2008, 15:23 by leegt5 »
Offline carlgti
« Reply #7 on: 15 October 2008, 19:24 »
ah i think this may be the problem with mine, glad i just found this because i literally just noticed the play in my steering column tonight.
Offline GOLF_MK
« Reply #8 on: 15 October 2008, 21:01 »
thanks lee gt5, i'm hoping to get some time at the weekend to have a proper look so this has given me more ideas!
Offline Rmachines
« Reply #9 on: 15 October 2008, 22:20 »
tbh it would probably stay an advisory for the next 5 years anyway  :smiley:
