Golf mk3
hardmonkeys
Sunroof Drains
Topic: Sunroof Drains (Read 1215 times)
rtb51
Sunroof Drains
12 October 2008, 01:26 »
HELP, I've searched around the internet and can't find any accurate info on Mk3 sunroof drains.
Where are they ?
It's a factory fitted glass sunroof. With the roof open there is an inner black plastic runner which seems to obscure where the drains might be ie in the front corners. I don't really want to remove the whole sunroof to fix the leak.
Has anybody else had a problem with blocked drains and managed to fix it ?
ace
Re: Sunroof Drains
12 October 2008, 12:15 »
need to open the sunroof all the way back, and u will find them in the front corners, one either side.
u will need to look for them as they aint the easiest things to see!!!!
kells
Guest
Re: Sunroof Drains
12 October 2008, 13:20 »
they are not only on the front corners, they are on all 4 corners
you can see where the front ones come out, its above the hinge on the front door, looks like a little rubber tube about a cm long
Golf mk3
hardmonkeys
Sunroof Drains
