Author Topic: 1.8Turbo - misfire under acceleration?  (Read 2721 times)
Offline Cosworth Lee
« on: 11 October 2008, 22:09 »
Hi my mates just bought a 2001 1.8T GTI.
when the engine is at full operating temp, and under load there is a misfire?
First thoughts are the coil (think there is one for each plug?) or even the plugs or leads them selves?
Just wondered if anyone has experienced similar things or has any ideas?
thanks.
Offline richw911
Re: 1.8Turbo - misfire under acceleration?
« Reply #1 on: 11 October 2008, 22:13 »
thanks.
Get it on vag com or a code reader to find out for sure.
Could be a number of things temp sender,Lamber sensor, Coil packs as you said very common.
If there are no fault codes  99% it will be the MAF sensor.
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #2 on: 12 October 2008, 11:28 »
thanks.
+1
Try genuine coil packs which cost areund £30 each, the cheap copies are pants.  Geniune bosch reburb MAF around £80 which includes a £25 surcharge.
Nick
 01455 617233
« Reply #3 on: 12 October 2008, 22:21 »
thanks guys, i will let him know. were pretty sure its a coil pack, so will buy one and then just swap it about untill the right one is eliminated!
