Author Topic: mk2 8v digi, loss of power  (Read 1773 times)
Offline rat-look
« on: 11 October 2008, 16:06 »
had a full tune up ran like a dream for a week or so, then lost power , engine runs when stationary a bit rich, but idles ok, but if i try and drive it there is just no power, any ideas?
Offline Mk2Kezza
Re: mk2 8v digi, loss of power
« Reply #1 on: 11 October 2008, 17:57 »
Possibly a dodgy blue temp sensor. If thats not reading correctly then the ecu will be over compensating the mixture, hence the rich running. Try changing that.
<br />Almost finished.....
Offline rat-look
« Reply #2 on: 11 October 2008, 18:06 »
its got a new sensor , but its a gsf one, ive heard they can fail ?
Offline Uruk Hai
« Reply #3 on: 11 October 2008, 18:07 »
Check for vacuum leaks.
Offline mattkh
« Reply #4 on: 11 October 2008, 19:32 »
Hi
What is the best way to check for vacuum leaks ?
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #5 on: 12 October 2008, 09:39 »
GSF blue temp sendors cr@p. VW dealers sell them for £15......tons better  :smiley:
Might aswell replace all your vac hoses in the engine bay. Easy enough job and cheap.
Also I would check the throtle bodie sender. There are 2 wires coming from this sender......check they have not broken as thats fairly common.
Offline rat-look
« Reply #6 on: 12 October 2008, 12:51 »
all the vac is good and the senders all ok, found a hole in the middle section of the exhaust, checked every thing over and took it for a spin, its about 50% down on power, would the hole have this much effect, could it be a fuel problem?
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #7 on: 12 October 2008, 13:56 »
Hmmm..... would'nt have thought so mate......unless the hole is huge!
Trying to think here.....
Have you recently put supermarket fuel in her as my Digi ran like a dog on that! I always used BP 97ron or Shell 99ron. Also injector cleaners....used a bottle of STP on mine every 10 weeks.
Only other thing I can think of is the throttle bodie sender. If thats up the creek it wont be letting the flap open fully to release full power.
The King of Kings when it comes to Digi's is Rubjonny....hopefully he will read this thread  :smiley:
Offline ToddyGTi
  • I Love GTi's
« Reply #8 on: 12 October 2008, 15:46 »
Dead AFM is certainly a possib :wink:
Part of the Booty Club
Offline rat-look
« Reply #9 on: 12 October 2008, 21:09 »
have been using the optimum stuff that they sell, just ran the last tank with stp, any one got an afm will give that a go and replace the throttle body sender..
