Author Topic: Snapped Throttle screw  (Read 1013 times)
Offline simpleton
« on: 11 October 2008, 10:20 »
Hi all firstly may i thank you all for your posts on my 57i kit what a joke they are im now changed it to a standard box but am still having a few wee problems.
i have done a full service thats plugs leads dizzy cap rota arm oil filter air filter oil etc.
i am now trying to get my car to idle on 1000,i have checked the isv switch and all working fine,so i decided to losen the 8mm nut and unscrew the throttle screw but its snapped :cry: if i get one of a mk3 golf or a passat will that dpo as there isnt any gti'sin my local scrappy?
this morning i have noticed that it has a wee wee mis-fire and am wondering if that could be my problem but sure;y that wouldnt make my needle fluctuate.
Offline Conker
Re: Snapped Throttle screw
« Reply #1 on: 11 October 2008, 16:07 »
If you've got a miss-fire I would sort that out first as it might cure the idle problem. If not then you can look into sorting out the idle problem afterwards, as its a less serious problem vs a miss-fire.
There are loads of threads that can help you with both problems, so use the search function and sit down with a cup of tea for a good couple of hours of research!
To start you off...
MISS-FIRE
 - Plugs
 - Leads
 - Rotor arm
 - Dizzy cap or dizzy itself
 - Coil
IDLE
 - Air leak
 - The ISV needs cleaning
 - The idle/CO settings needs re-setting
 - Clean all breathers and air intakes
Ad infinitum...
sharpie
« Reply #2 on: 11 October 2008, 16:21 »
add f**ked rocker gasket to the missfire list.
Offline danny_p
« Reply #3 on: 11 October 2008, 22:55 »
thats more a 16v thing.
misfire are normaly a plug related issue
all the VW's have gone bar 1.
Offline simpleton
« Reply #4 on: 12 October 2008, 17:08 »
just a quick recap for you all today i have now replaced all the vacum hoses and also cleaned all pies etc,i have now set the idle to 950ish carnt do any better but i must say it runs,sound and feels alot better.
just a quickie i have looked at the air flow meter which is situated above the rocker cover on a big rubber holder how can i tell if i have the right one on ie what the difference between a 1.8 and 2 litre module.
Plus would somebody be most kind and upload me a picture of a isv switch please as im getting mixed up which one its supposed to be.
thanks alot guys
simp
Offline sidecarphil
« Reply #5 on: 12 October 2008, 18:16 »
the thing your on about is the idle speed control valve  :smiley:
the air flow meter it in the airbox i think  :smiley:
Offline richard s
« Reply #6 on: 12 October 2008, 20:49 »
idle control valve is in front of the inlet manifold and is fed from a pipe that comes from the ufo on the rocker cover
Offline sidecarphil
« Reply #7 on: 12 October 2008, 21:06 »
 :grin: :grin: :grin: :grin: :grin: :grin:
