Author Topic: Got a oil leak  (Read 1649 times)
Offline ukdub
  • WH05 DUB its my DUB
Got a oil leak
« on: 10 October 2008, 23:11 »
Oil is leaking from the cam chain cover on the right side of the engine, dripping on to the gearbox then on to the drive.  Not silly amounts, but enough for me to be concerned.  What I would like to know is,  If the PCV fails can oil be blown out of other areas of the crankcase or just the oil filler cap.  I think it is the PCV because of a slight drop in performance.
Any help would be bob on.
« Last Edit: 11 October 2008, 00:44 by ukdub »
Laser blue with BBS CH wheels in 19"
APR software, APR RSC turbo back exhaust, APR HPFP, Dbilas flowmaster intake, KW V3's
BSH speedshop PCV stage 2 fix but with Forge catch can
Offline gazbutmk5gti
Re: Got a oil leak
« Reply #1 on: 11 October 2008, 00:13 »
you don't have a cam chain
Revo stg2+ & lots more
Offline ukdub
Re: Got a oil leak
« Reply #2 on: 11 October 2008, 00:43 »
Not the timing belt side of the engine.  The right hand side of the engine where the chain drives the 2 cams
Offline ukdub
Re: Got a oil leak
« Reply #3 on: 11 October 2008, 21:27 »
Anyone?  What are your thoughts to the PCV idea? :huh:
Offline Fatty B
Re: Got a oil leak
« Reply #4 on: 11 October 2008, 21:33 »
on the mk4 golfs when the pcv become faulty it would log a fault in the engine ecu. try and get a code reader and check the car before assuming that is the problem chances are they aint cheap also have you check cam cover gasket and surrounding area for oil leaks ?
If your buying im selling!!!!!!!
Offline Top Cat
Re: Got a oil leak
« Reply #5 on: 11 October 2008, 21:40 »
You could try the new service. in the stickies you can e-mail the doc for help.  :smug:
