Author Topic: transmission from tdi to abf?  (Read 1768 times)
Offline ZIZZ
« on: 10 October 2008, 21:24 »
hi :)
i would like to get shorter gears, so better acceleration.. i have transmission from tdi, does it fit abf? 1z code of machine...
and also, if i try, should i tako off flywheel from tdi or just everything but the flywheel, because tommorow is saturday and i'm going to try it :)
VeeDubClub
Re: transmission from tdi to abf?
« Reply #1 on: 10 October 2008, 21:58 »
I cant see the tdi gearbox making much difference tbh! And im sure the clutch would need to be changed.
I have a mk2 1.8 box on my mk3 gti and that made a noticeable difference but i needed a complete new clutch in order for it to fit.
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #2 on: 11 October 2008, 13:36 »
Isnt the diesel the opposite?  has longer ratios for a stronger lower power output?    you want to bodge a 1.4 box on it  :grin: thats pretty impossible and it would smash into shards but wow imagen the acceleration,  would top out at 80 tho  :grin:
Anyway im not being helpfull...  i would like to know if the clutch is the same on the derv as the abf,  its the same box and the derv has alot of torque so mabey it is?
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline ZIZZ
« Reply #3 on: 11 October 2008, 21:07 »
i ment to do it because clutch and all inside was broken.. ball bearing fall apart and broke all other... but we did it... we took clutch, pressure plate and ball bearing from tdi and put it to Abf, and it's rolling :)  :evil: :evil: :evil:
i'm driving  :laugh: :laugh: :laugh:
