Author Topic: creaking noise  (Read 2336 times)
Offline daniel-1986
creaking noise
« on: 10 October 2008, 16:55 »
everytime i pull off there is a creaking noise coming from the drivers side, my dad said it could be the wishbone bushes but it doesnt do it over heavy bumps, the only thing i can think of is the rear engine mount but it was fine at 2 o'clock then came back to drive it an hour later and the noise started
« Last Edit: 10 October 2008, 17:00 by daniel-1986 »
Offline dubmaster77
  • actualy on the road!
Re: creaking noise
« Reply #1 on: 10 October 2008, 17:14 »
Check your ront engine mount.... Then check your subframe is tight!! I had a creaking every time I went into reverse and it turned out to be the subframe was loose!!
K-Jet is my friend!
Offline daniel-1986
Re: creaking noise
« Reply #2 on: 10 October 2008, 17:36 »
i went over speed hump whilst braking from 20 mph and it quite a nasty bump with pothole just in front of it, could this have loosened the subframe bolts
sharpie
Re: creaking noise
« Reply #3 on: 10 October 2008, 17:41 »
have a look and see instead of just speculating.
Offline DarnPB
  • Formerly Darnpistonbroke
Re: creaking noise
« Reply #4 on: 10 October 2008, 18:41 »
Have your wheels been off lately? I had the same on a Passat and found that the numpties at the garage had not tightened up the wheel bolts! I only found out when I went to remove the wheels to investigate the problem. I though it was a suspension bush. I rechecked the other wheels and they werer all the same. :shocked:
Offline oakgreen_91
Re: creaking noise
« Reply #5 on: 10 October 2008, 18:46 »
Could also potentially be your suspension top mounts
2012 Audi A4 Avant Black Edition TDI 177
2012 Megane RenaultSport 250 Cup
1991 Volkswagen Golf GTI 8v
1990 Renault 5 GT Turbo
Offline daniel-1986
Re: creaking noise
« Reply #6 on: 10 October 2008, 20:18 »
i jacked the car up and shook the wheel for play but couldnt feel any play plus when i set off you can sometimes feel vibration in the steering wheel
Offline daniel-1986
Re: creaking noise
« Reply #7 on: 11 October 2008, 16:25 »
heres the noise im talking about
its easier to explain with a video
Offline Mk2Kezza
Re: creaking noise
« Reply #8 on: 11 October 2008, 17:55 »
Could be top mounts or the wishbone rubber thing? Had a similar noise on mine recently and changed the wishbone and top mounts - no noise now  :smiley:
<br />Almost finished.....
Offline daniel-1986
Re: creaking noise
« Reply #9 on: 11 October 2008, 19:19 »
if i put the car on axles stands with boths off the ground and put in first gear, would this put enough pressure on the rear engine mount to make a noise if its fooked
