Author Topic: gearbox oil leak mk3 gti  (Read 1815 times)
Offline dardo
« on: 10 October 2008, 16:21 »
can anyone shed some light on this for me decided to top gearbox up with oil 2day and on doing so the gearoil i was putting in started to leak out of the bell housing is there a seal possibly gone on it
Re: gearbox oil leak mk3 gti
« Reply #1 on: 13 October 2008, 10:19 »
argh, did you fill it thru the plastic bung on the top close to the engine block? if so you might have fked your clutch. that is NOT where you fill the oil, that is the flywheel inspection hole so you can set/check the timing  :cry:
the correct place to fill the oil is the 17mm allen plug on the side of the gearbox, you fill it till oil starts to comes out of there. though what I would do is take out the filler/level plug and fill it thru the speedo cable/sensor hole near the back in the toip, much easier.
Offline strac
« Reply #2 on: 08 June 2009, 19:09 »
Damn i done this today now i have a leak near my drivers side drive shaft
any clues on how to fix this?
Rust is lighter than carbon fibre.
