Author Topic: Fitting tie rods to PAS on a 16v  (Read 974 times)
Offline gixerthrasher
« on: 08 October 2008, 12:20 »
I've just had a flick through my "Pains Manual" at fitting new tie rods, seems a bit of a mare..?
Can you guys tell me if it's possible to fit the new tie rods without removing the PAS rack please.. I've never done these before.
Thanks for any advice.
Never hold your farts in.. They travel up your spine and into your brain and that\'s where sh!tty ideas come from!
Re: Fitting tie rods to PAS on a 16v
« Reply #1 on: 08 October 2008, 17:02 »
do oyu really need to replace the whole tie rod?  just the ends is easily doable with the rack on the car :)
VeeDubGTI16v
« Reply #2 on: 08 October 2008, 17:07 »
doing the rods is an absolute bastard in situ. i had to make a crows foot out of an old spanner to get them off!
Offline m9olo
« Reply #3 on: 08 October 2008, 20:40 »
It is possible without moving the rack, i've just done mine but i removed the wishbone as i was putting new bushes in. I found if you warmed the nut on the end of the rack with a blowtorch it came undone with a pair of adjustables.
Offline danny_p
« Reply #4 on: 08 October 2008, 20:42 »
never round getting these off to be an issue, may just have been lucky so far
all the VW's have gone bar 1.
« Reply #5 on: 09 October 2008, 00:22 »
Thanks guys, I'll give it a go as I've got to replace both wishbones as well..
The old tie rods are well & truly corroded, as is/was nearly everything on the car from years of salt spray on our roads!
So far £2000 & counting on new stuff as I just can't bear to part with this awesome piece of German design.. Love it to bits (literally)
Many thanks to you all on this forum, you've been a great source for info & inspiration.. :wink:
