Author Topic: New cabby  (Read 2563 times)
Offline 98mpart
New cabby
« on: 07 October 2008, 19:05 »
I have just bought a mk1 cabby, wrong time of year i know. It has a weird idle problem, when its started idle is lurvly @ 950rpm but after going for a drive and running to temp the idle sits proper high at like 1500rpm and doesn't drop back. Any ideas ????
Re: New cabby
« Reply #1 on: 08 October 2008, 17:02 »
what year/engine ;)
Offline Neaty
Re: New cabby
« Reply #2 on: 08 October 2008, 17:03 »
Sounds like a carb model with a sticky automatic choke on those lovely pierburg carbs
Re: New cabby
« Reply #3 on: 08 October 2008, 17:09 »
I'd say its more likly to be the waxstat if its a carby!  if it was autochoke it would generally run like arse from cold :)
Offline Neaty
Re: New cabby
« Reply #4 on: 08 October 2008, 17:20 »
mine never used to on my Scirocco, was fine until it was warm then it would idle at about 2k. But who am I to contest! :grin:
Re: New cabby
« Reply #5 on: 08 October 2008, 17:22 »
mine was the opposite, ran like an absolute dog till it warmed up as choke stuck on so overfueled, then idled at 2k for a long time.  If the engine was runnign for long enough it would run perfect as engine heat eventually disengaged the choke & stat.
Offline 98mpart
Re: New cabby
« Reply #6 on: 08 October 2008, 19:23 »
Tis a 1990 1.8 8V kjet
so not a carb issue, cheers tho.
Offline Neaty
Re: New cabby
« Reply #7 on: 08 October 2008, 19:29 »
Have you tried disconnecting the 5th injector? My mate had a similar problem on his Mk1 and took that off.
Offline kraM
  • It's not the speed, it's the sudden stops...
Re: New cabby
« Reply #8 on: 11 October 2008, 23:07 »
Hi
It sounds like the air by-pass thingy is sticking open, or has become disconected.  It sits behind the inlet manifold, has a 2 wire plu on it and has a pipe in and out of it.
It works by letting the air through it form cold (a bit like having your foot slightly on the throttle), and as it gets a voltage through it, the bi-metalic strip in it moves, covering the hole and lowering the revs.
If it is connected, try blocking the pipe, use a pair of molegrips to crush the RUBBER part of the pipe closed and see from there.
If that doesn't fix it, let me know and I'll come up with another cunning plan...
kraM
It's not the speed... it's the sudden stops...
