Author Topic: Limits of the ED30 tuning  (Read 9873 times)
Offline Hurdy
« on: 07 October 2008, 04:13 »
So everyone,
I've been reading the GOLF+ feature on the 2.0 TFSI engine and the various upgrades that are available with the stock K04 on the ED30 and the upgrades from the standard GTI to a K04. Most say that they are only tuning into the early 300+bhp, but what exactly is the limit of the ED30 in terms of power and bhp without changing the turbo, but changing all the other bits that count (remap, zorst, HPFP, I/C etc).
Tuners all seem to be quoting between 300 to 340bhp :undecided: and up to 335lbft.
I already know Vtec has managed over 360lbft and I have had 333bhp, so surely these must be approaching the upper limits?
Seat Leon Cupra Black 290 DSG
Offline Saint Steve
Re: Limits of the ED30 tuning
« Reply #1 on: 07 October 2008, 08:22 »
Why is it an ed30 with a wrong bore exhaust (2.75'' instead of Correct 3'' has this super high 360Lbs ft of torque??? , How can that be, surely thats gonna have a prefound effect on the Engines potential torque??.Isnt that just like putting a Cat back system on instead of a Full System???.
Im Bemused??.
Offline Vtec Abuser
« Reply #2 on: 07 October 2008, 08:44 »
Im Bemused??.
I was a little suprised that it made the torque it did to be honest. But it did it on 6 different runs on 2 different days. Would still like to see what it makes on other rollers to compare though..
As for the DP, fook knows. Might have something to do with the back pressure..  :huh: TT? I know DJ Horace said he wished he had gone with the 2.75" now instead of the 3".. :huh:
Candy White Ed30 3dr DSG, Nav, Bi-Xenons, Armrest, MFSW...
Offline john_o
« Reply #3 on: 07 October 2008, 08:46 »
Phil my comments
It seems to be a strong std car
Its on APR rollers (which may read high)
Its on that style of dyno (dynamic) with various correction factors
REVO hits very quickly at low rpm (very noticeable in Hurdys prev graph comparisons) , so maybe this combined with the way its measured skews the 'measured' torque peak
We would need a before/graph for vtecs car on the same dyno/same day (pre and post mods)
I'd be interested to see Vtecs EGR readings under full load tbh
as for the exhaust, I think the milltek still removes some of the other restrictions.
Small bore can be better in terms of flow at lower rates.
This in theory could help the very quick spool/torque peak seen in vtecs car
What we dont see though is the higher rpm 'limits' that supposedly tuners say we need a 3 inch bore for!
In theory vtecs car should perform better at lower rpm then flatline at say 6500rpm ?
Black 3dr Edition 30 manual
DEFi boost gauge | ECS Dogbone | WLineAntiLiftKit
Offline MAT ed30
« Reply #4 on: 07 October 2008, 09:47 »
Im Bemused??.
i have an idea i will put my stock dp back on the car for the rr day and then me and ben will be running the same but me on stock dp and ben tell us what revo settings your running and i will run the same and then we will see what happens.
EDITION 30 NUMBER:- 1038 ,Forge dv,ecs dog bone insert,Tints,inpro smoked indicators,panel filter,Black badge,Black roof,Black wing mirrors,REVO stage 2,Blueflame TBE,neuspeed arb,Neuspeed drop links,KW V3,S3 Intercooler,VWR clutch and LSD,VWR 6 pot brakes,1956 vw beetle (2332cc)
Offline Vtec Abuser
« Reply #5 on: 07 October 2008, 10:07 »
Is the stock DP 2.75"???  :shocked:
At the end of the day guys, I don't see mine being anymore powerfull than other ED30 with the same mods. K4iths ED30 ran only anout 10bhp short of mine on the same day, but he only had the Map and intake, no TBE.
Mat's will be a good test, as he also has Revo and Milltek, plus a few other little bits. So on the same rollers should make for interesting results. Only thing is, what rollers, Prosport or Weston's?  :undecided: As if us guys at Prosport get good results, then I can just see the same arguments coming up again about whether they're as good as DD rollers..
What to do eh..  :sad:
Offline Vtec Abuser
« Reply #6 on: 07 October 2008, 10:11 »
Oh crap (doh!), Mat don't forget i'm Stage 2 now.. What difference it'll make I don't know, a little bit I hope..  :wink:
Offline MAT ed30
« Reply #7 on: 07 October 2008, 10:14 »
thats ok fella i have a mate who is a revo dealer in halifax so might get it put on  :wink: but keep stock dp just to see how it goes.
« Last Edit: 07 October 2008, 10:17 by MAT ed30 »
Offline Vtec Abuser
« Reply #8 on: 07 October 2008, 10:15 »
Only £50 sheets mate, so may as well..
Offline MAT ed30
« Reply #9 on: 07 October 2008, 10:17 »
you are stage 2 not stage 2 + as you dont have a pump
