Author Topic: Car not warming up....  (Read 2724 times)
Offline raks.2008
  • 1992 MK2 16V
« on: 06 October 2008, 08:17 »
Noticing more as its getting colder....!
Everyday starting the car from cold, I drive to work 5 miles at around 50mph and it just warms up to a quarter. Is this normal?
I think it is taking its time warming up if i am not wrong? Can it be the thermostate that requires changing? or something else....?
Thanks
Offline Village Idiots
Re: Car not warming up....
« Reply #1 on: 06 October 2008, 08:37 »
Thermostat would be a good place to start. Have fun changing it!
Offline Cosworth Lee
« Reply #2 on: 06 October 2008, 08:38 »
99% sure u need a new thermostat.
simple job, takes about 5 mins to do.
remove the outlet pipe, (maby place a tray under to catch the anti freeze, u'll loose a few pints!)
unbolt the case (3 bolts i think)
simply pull out stat, install new one, and put back together
top up antifreeze.
run it and take it out for a drive
recheck fluid leves and be sure no air locks are present
a thermostat will cost about £15 from Vw, or about £10 from halfords!
Im very cettain its the stat, but if u want to be sure before u buy a new one, then boil some water and put in a clear glass jar.
if its works the stat should click and the diaphram/spring will open
but if its fooked like id imagine then it will do nothing
Also if ur feeling in the mood when u change the stat u can flush out the engine and rad with the hose, and put in new coolant, but again be aware of air locks!!!!
Offline JC
  • Back in the North.
« Reply #3 on: 06 October 2008, 08:40 »
unless you have PAS fitted of course, then its NOT a 5 minute job as described  :wink:
« Reply #4 on: 06 October 2008, 12:06 »
coolant faq!
« Reply #5 on: 06 October 2008, 16:01 »
It when u have a car with aircon, then its a real bugger, you can gurantee what ever u want to do an aircon pipe will be in the bloody way!
Offline Conker
« Reply #6 on: 06 October 2008, 19:41 »
In only five miles, that sounds about right to me - its been chilly lately?? Compare the water temp to your oil temp - Am I right in thinking if your oils getting hot but your water isn't, then that helps diagnose a thermostat fault?
In a morning at the moment, my 16v just gets into the nineties on the MFA by the end of my journey, which takes 20 minutes at 45mph.
Offline Dolly
« Reply #7 on: 06 October 2008, 21:17 »
bit crap with PAS, my engine was out when i did it, and i did think i wouldnt fancy it in situe lol... my advice any job just take the engine out then its a piece of cake  :smiley:
Offline Conker
« Reply #8 on: 06 October 2008, 21:45 »
Intended for this one by any chance?? http://www.golfgtiforum.co.uk/index.php?topic=93952.0
 :grin:
« Last Edit: 06 October 2008, 21:47 by Conker »
Offline AdamMk2
  • Beautiful
« Reply #9 on: 07 October 2008, 07:31 »
 :sad: I thought quarter was normal  :huh: Only very rarely in traffic mine goes to half  :shocked:
is this normal?
