Author Topic: help me reach 100! - update! GTI HEAD BOUGHT!  (Read 38704 times)
Offline Mew
Re: help me reach 100! - update! GTI HEAD BOUGHT!
« Reply #160 on: 13 October 2008, 19:45 »
Pretty sure gsf do, they definitely do the nuts...
Offline sidecarphil
« Reply #161 on: 13 October 2008, 19:54 »
you then can just use moley grip's to remove them :)
also if you got a little heat gun i would warm the head/the stud's a little first , makes them easier to remove
 :grin: :grin:
Offline richard s
« Reply #162 on: 13 October 2008, 20:23 »
about the studs for the rocker cover if you do a search im sure rubjonny has posted something about fitting ones for a mk3 gti will enable you to use the rubber gasket instead of the cork one
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #163 on: 13 October 2008, 20:23 »
 :grin: :grin:
And if they don't come out, you are left with a knackered stud that nothing will screw onto! Mole grips are a last resort for beasting things out with.
Offline Khare
  • The bear that khares
« Reply #164 on: 13 October 2008, 20:24 »
the head came with a rubber one when i bought it, so im sure it can be fitted using mk2 studs.
Offline sidecarphil
« Reply #165 on: 13 October 2008, 20:29 »
could it be off a mk3 GTi ???
Offline Khare
« Reply #166 on: 13 October 2008, 20:30 »
no, im pretty sure its from a mk2 lol.
Offline Steve_B
« Reply #167 on: 13 October 2008, 20:45 »
studs for a cork gasket have a shoulder on them, on a rubber gasket the metal ring is in the gasket not studs.
Offline danny_p
« Reply #168 on: 13 October 2008, 20:46 »
it's a late mk2 head
all the VW's have gone bar 1.
Offline Khare
« Reply #169 on: 13 October 2008, 21:12 »
this is the studs ive got. rubber gasket correct?
