Author Topic: help me reach 100! - update! GTI HEAD BOUGHT!  (Read 38699 times)
Offline Khare
  • The bear that khares
Re: help me reach 100! - update! GTI HEAD BOUGHT!
« Reply #150 on: 13 October 2008, 18:09 »
finished reconditioning the tappets. Now i just need to buy some bolts and get the head acid dipped and skimmed.
need to know 2 things first.
How do i take out the bolts that the exhasut manifold bolts to? (also the ones the valve cover bolts on)
And
Where can i get some more? (need 2 for exhasut (one i had to drill the nut out and it went into the screw, other is stuck to the nut so it unscrewed from head)
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #151 on: 13 October 2008, 18:38 »
To remove the studs, fit two nuts onto one stud and tighten them up against each other, but don't over do it. Use plenty of penetrating oil, then gently work the nuts back and forth until the stud starts to move, then start, again gently, removing the stud. To refit them or fir new ones, degrease the threads thouroughly, both male and female threads, and fit studs the same way you removed them, but use thread lock too, to prevent them from coming out again.
Offline Khare
« Reply #152 on: 13 October 2008, 18:40 »
cheers dude :wink:
Offline Steve_B
« Reply #153 on: 13 October 2008, 18:54 »
Give the studs a few taps with a hammer as well, seemed to help in my case.
Offline DarnPB
« Reply #154 on: 13 October 2008, 19:12 »
As regards the pitting,...pitting is caused by corrosion due to the proximity of water, or moisture contained within an area. Acidic fluids will aggravate it causing the corrosion to become apparent more rapidly. Not much you can do about it except for skimming or weld reairs if it is too severe.
Offline Khare
« Reply #155 on: 13 October 2008, 19:18 »
from what you see in the pics, is there any pitting?
Offline DarnPB
« Reply #156 on: 13 October 2008, 19:22 »
Er yes! Around the exhaust ports and water jacket. But not too much that would scare me. You will get away with a good clean up and decent gaskets.
Offline Khare
« Reply #157 on: 13 October 2008, 19:28 »
exahsut ports are just extremly dirty full of carbon. Dont think that is pitting :undecided:
Offline sidecarphil
« Reply #158 on: 13 October 2008, 19:35 »
dont worry about pitting in the port's fella , usually just on the head face and the water jacket's :)
i would change all the exhaust stud's , you will be glad of it in a few year's if you wanna take the exhaust off  :wink: :wink:
Offline Khare
« Reply #159 on: 13 October 2008, 19:38 »
yeha i wanna change them all too. Saves elbow grease when it comes to fitting too.
where can i buy them from?
