Author Topic: Mk2 Injector rail etc  (Read 4058 times)
Offline Rixy
« on: 05 October 2008, 19:00 »
hi, can the mk2 golf gti 8v injector rail be removed from the head without removing the inlet manifold? only reason im asking is because i went to set my digi up earlier, and could hear a whistle - then i wiggled all the vacuum pipes etc, and noticed its comin from the inector rail. Gonna order some new seals etc from gsf i think, but dont wanna have to pull the inlet etc all off if i can get away with it.
also, the little caps under the injectors, that the seals seat on, do they remove with an allen key, as they look like the do, and if so, does any1 now what size??
Offline Mr Blue
Re: Mk2 Injector rail etc
« Reply #1 on: 05 October 2008, 19:06 »
Does it run ok?
Better to remove the inlet. Not much work and way easier.
I used a large flat head screw driver to undo those seals on the head (shoddy). Did the job! Sorry dont know the allen size.
I doubt the whistle is coming from the injector rail. Double check the vacume pipes
Offline Rixy
« Reply #2 on: 05 October 2008, 19:11 »
well it runs ok, but very lean top end etc, which is what also makes me think its pullin air in elsewhere. The whistle is deffo comin from the rail, as if i wiggle the rail, i can make it stop, or louder, depending on which way, and i did this whilst making sure i didnt move anything else, if ya know what i mean?
i will just remove the inlet then i think.....and see what i can do. So do the allen head thingy's undo very well, or are they a b!tch, and can i buy them new from vw, or do gsf do them?
does any1 have part numbers for the seals etc?
Offline Mew
« Reply #3 on: 05 October 2008, 20:03 »
Injector rail will come off without removal of the inlet manifold, bit of a b!tch to put it back on though.
Offline danny_p
« Reply #4 on: 05 October 2008, 20:56 »
digi 2 allways leans out up top unless its been fetteled
all the VW's have gone bar 1.
« Reply #5 on: 06 October 2008, 12:08 »
aye as said can be done with inlet on but its a right mare.
Offline clipperjay
« Reply #6 on: 07 October 2008, 11:51 »
Injector Rail - 037 133 317 L -
Injector Seal Kit x 4 - 030 198 031 -
Injector Wiring Loom - 037 133 339 B -
Jay
« Reply #7 on: 07 October 2008, 11:56 »
make that x5 for the seal kit, do the fpr seals while you're there :)
Injector Rail - 037 133 317 L - 40.39+VAT (doubt you'll need this, unless you bust it!)
Injector Seal Kit x 4 - 030 198 031 - 3.53+VAT
Injector Wiring Loom - 037 133 339 B - 51.50+VAT (again doubt you need this)
« Last Edit: 07 October 2008, 11:58 by rubjonny »
Offline Mew
« Reply #8 on: 07 October 2008, 12:24 »
Might put my spare one on ebay if they go for anything like that 2nd hand!
As for the rail itself, be careful when tightening up the fuel hose from the FPR, too tight and you'll crack the plastic resulting in a new rail, not that i did that :lipsrsealed:
Offline Rixy
« Reply #9 on: 07 October 2008, 22:29 »
awesome stuff, i'll get them ordered tomorrow then, but.......does any1 know what size allen key i need to remove the old kjet injector inserts and what size to re fit the new digi type ones? can these be bought from vw? as im running the wrong ones....hence why its leaking!!!
