Author Topic: Mk2 8V Idle problems?!  (Read 1493 times)
Offline AdamHowarth
« on: 05 October 2008, 17:24 »
Arrrrrrrgh!
Advice at this point would be much appreciated. Iv got an idle problem on My 8v GTi where it fluctuates between 750 Rpm and 2000!
Iv carried out so many apparent remedies for this which have sometimes helped slightly but never truly cured the problem.
Soaked the ISV in petrol to clean out any crap....
Changed the mass air flow meter....
New spark plugs, distributor cap, rotor arm....
New airfilter....
I heard somewhere on the grapevine that cleaning out the throttle body can sometimes sort it! Does this sound farmiliar to anyone and if so how do i go about doing it?
Many thanks people!
« Last Edit: 05 October 2008, 17:33 by AdamHowarth »
Offline Mr Blue
Re: Mk2 8V Idle problems?!
« Reply #1 on: 05 October 2008, 19:01 »
Check the wires on the throttle body. They always break.
There is a throttle switch hidden at the bottom and the one at the top. check if they 'click'
Offline needtogofaster
« Reply #2 on: 05 October 2008, 20:22 »
I've had similar probs, my timing was slightly out made a difference.Was causing occaisional stalling also.
Offline jammac
« Reply #3 on: 05 October 2008, 21:08 »
mine was doing the same until i replaced the ISV with one i pinched from the scrappy!  :grin:
ITS A TRAP!
Offline Uruk Hai
« Reply #4 on: 05 October 2008, 21:37 »
Check for vacuum leaks and as said check the micro switches on the throttle body
Offline golf-manic
« Reply #5 on: 05 October 2008, 22:46 »
ive had a similar problem when the car is warm, it sits at about 2000 n slows down to regular after a while.
ill try some of these and post what i find for anyone who has the same problem
Offline raks.2008
  • 1992 MK2 16V
« Reply #6 on: 06 October 2008, 07:58 »
Sometimes cleaning the ISV does not make a disfference if it is buggered.... Does it only happen in the morning or all the time.
Check Cold start valve,
Check your vacume pipes on you air intake pipe under the throttle body,
Check your timing.
Offline AdamHowarth
« Reply #7 on: 06 October 2008, 18:49 »
Guys guys! thanks a lot for all your advice, will defo try the wires. I get a popping from my exhaust from time to time when slowing down so timing could well be the issue. Thanks again.
By the way racs.2008.......... It happens all the time really, never totally consistent though. And thats a sh!t hot 16 valver matey!
« Last Edit: 06 October 2008, 18:51 by AdamHowarth »
Breaker
« Reply #8 on: 06 October 2008, 18:54 »
Try borrowing another ISV
My last one was on the way out got stuck at 2000 sometimes,
tried cleaning it and then it wouldn't idle at all, quick trip to the scrappy solved that.
Offline simpleton
« Reply #9 on: 06 October 2008, 19:02 »
can anyone post a picture of a ISV for me please im getting mine to idle at 850 then i turn the wee screw and it jumps to 1200 so im sure one of these switches has gone could some kind person post a piccy please
