Author Topic: please shed some light chaps 8v wont start  (Read 1937 times)
Offline serafumi
« on: 05 October 2008, 16:41 »
Hi guys, i have been the happy owner of an 8v digi since feb 08 ..... been using the car quite alot lately, i serviced it when i brought it. plugs , leads rotor arm dizzy cap , blue temp sensor and car has been fine ever since this morning!!!! i went out to car turned the ign on , fuel pump primed as normal. it turned over but failed to start!!!!
is there any advise u chaps can give me as where to start looking???
cheers for your help
Offline Mew
Re: please shed some light chaps 8v wont start
« Reply #1 on: 05 October 2008, 16:52 »
Have you got a spark?
Offline serafumi
« Reply #2 on: 05 October 2008, 16:59 »
havent had chance to check cause batt went flat ..
Offline aj_golf
« Reply #3 on: 05 October 2008, 21:07 »
is it turning over?
if it is and not starting check your ecu!!
i changed me speedo cable an knocked i an it come lose
sounds silly i knw but its a shot in the dark!!!
plus you bin doin alot to it!!
Offline serafumi
« Reply #4 on: 05 October 2008, 21:44 »
hi everyone .... it turns over fine , fuel pump primes ok .......yet it fails to start :cry:
Offline aj_golf
« Reply #5 on: 05 October 2008, 22:04 »
you checked r ecu?
try ur dizzee cap,roatry arm ...etc
cud be a few things reali
Offline Village Idiots
« Reply #6 on: 06 October 2008, 08:42 »
This may be obvious, but this is what engines need to run: fuel reaching the cylinder (in roughly the right amount); compression; a spark in the cylinder at the right time. Diesels don't even need the latter! Think logically until you find the fault.
Offline serafumi
« Reply #7 on: 06 October 2008, 09:33 »
right chaps i have been looking at golf this morning, and it doesnt spark  :angry:......... i have checked voltage at coil end but im only getting 7.8 volts can anyone shed any light to why im not getting 12v :angry: plese help
« Reply #8 on: 06 October 2008, 12:03 »
hmm, the black wire to coil comes direct from the ignition switch thru the fusebox, unless you have an alarm?  to confirm its this causing your problem, run a fused wire direct from the battery +ve to the coil black wire side, there should be a handy spare terminal.  If the car starts you know the fault is the ign live feed from the ign switch.  You dont want to keep it like that though, but if you do run it liek that for a while make sure you disconnect the battery side whenever you stop the car, coil doesnt like being energised for long periods of time without the engine running!
Offline serafumi
« Reply #9 on: 06 October 2008, 12:13 »
john i was waiting for you to appear . the GOD of mk2 golfs, i have fiddled some more and found the problem ..... i was checking the voltage going to the small ign module .. and i was only gettin 4v :angry:then with ign on i pulled a random fuse and muti meter showed 12v ... confused lots now lol . so i put fuse back in and fidled with fuse box and multi meter reading went from 12v down to 4v . so  i whipped the fuse box out and found a dodgy connector :grin: sorted that out and hooorah it lives again ...  :smiley: took me all morning to find it thou :embarassed: but best part was it didnt cost anything
so thanks again to all of you guys for your input
