Author Topic: Remap comparisons  (Read 3740 times)
Offline Hurdy
Remap comparisons
« on: 05 October 2008, 15:54 »
Here is the graph of Torque/revs as a rough comparison between cars.
Obviously the cars are at various stages of tuneage.
I'll get a power comparison up soon. :smiley:
These are lifted from Awesome GTI RR day and my recent RR day
Vtec - revo
Gaz - APR
Mine - CC
« Last Edit: 05 October 2008, 15:55 by Hurdy »
Seat Leon Cupra Black 290 DSG
Offline Hurdy
Re: Remap comparisons
« Reply #1 on: 05 October 2008, 16:15 »
Power comparison up too :smiley:
Offline bacillus
« Reply #2 on: 05 October 2008, 16:19 »
Is this a fair comparison seeing that the revo car did not have an uprated fuel pump?
Without traction power is nothing!
Offline Hurdy
« Reply #3 on: 05 October 2008, 16:23 »
You'll have to make your own mind up on that one. :smiley:
There are quite a few things you can make analytical judgements on like:-
Most of the other cars will be faster off the line than mine.
Ben's will most likely be the fastest overall.
Mine holds torque longer.
Mine would only be faster under maximum attack from 5.5k to the redline.
Ergo, fuel pump gives you extra at the top end.
I'm sure other deductions can be brought to play.
Mine has always been lower powered at the bottom end - even when standard against most other ED30's, roughly 15bhp/20lbft :sad: and similarly in other states of mapping, but I can't say that if my car was like the others it would get 345+bhp and 350+lbft can I? Maybe some people would say I could as the dyno was supposed to be reading 3% low :undecided:. Then again we are getting into that mad discussion again :laugh:
« Last Edit: 05 October 2008, 16:32 by Hurdy »
Offline chungster
« Reply #4 on: 05 October 2008, 16:28 »
very interesting torque comparisons tho....one being bit less than the others are lower end of the rev range!  wonder why they map it like that.  i suppose its smoother with no sudden "hit" like the others.
Offline gazbutmk5gti
« Reply #5 on: 05 October 2008, 17:03 »
problem is there Hurdy 2 of the cars are on the same rollers on the same day, then yours is run on a different one, different day. Not really an accurate comparison :smiley:
appreciate the effort you put in though :smiley:
« Last Edit: 05 October 2008, 17:19 by gazbutmk5gti »
Revo stg2+ & lots more
Offline SteveS
  • GTI ED30
« Reply #6 on: 05 October 2008, 17:08 »
im finding it hard to see the match the line colours with the key..? is revo the purple? seems low...
SteveS
ED30: Carbonio Intake & Filter | Blueflame TBE | Ebach Sportlines | Neuspeed Torque Arm Insert | Forge DV | REVO Stage2 [353BHP/360lb/ft]
Offline Vtec Abuser
« Reply #7 on: 05 October 2008, 20:32 »
Revo is the purple line, yes mate..
Revo is just the Stage 1 map, APR and CC have uprated Fuel pump, intake and stage 2+ software (and CC also has FMIC)..
Good effort there though Mr Hurditch :wink:
Candy White Ed30 3dr DSG, Nav, Bi-Xenons, Armrest, MFSW...
Offline john_o
« Reply #8 on: 05 October 2008, 23:21 »
nice try hurdy. I think we need all variances on the same RR at the same time  :nerd:
From what youve graphed , I dont understand the huge diff at 2500rpm , I can see why a map might reduce the torque levels , but I would still expect it to climb at the same point (you are even under the std car at this point!)
Was your car mapped specifically to avoid low rpm hit for the DSG?
looking at the graph Im surprised the REVO DSG cars dont jutst slip immediately after a remap  :evil:
Black 3dr Edition 30 manual
DEFi boost gauge | ECS Dogbone | WLineAntiLiftKit
Offline Hurdy
« Reply #9 on: 06 October 2008, 11:22 »
That is what I asked them for, but I didn't realise till I did the comparison that it was backed off quite that much :shocked:
