Author Topic: response  (Read 3171 times)
Offline jon007
response
« on: 20 May 2004, 15:52 »
I've got a 2.0 16v but it's unresponsive until the revs kick in. What can I change - I'm on a (girlfriend imposed) budget? Currently thinking splitfire plugs, K&N and boost valve. Also need to sharpen up the handling - Will stiffer springs do the job or do I need to replace dampers etc? ???
Offline Overseer
Re:response
« Reply #1 on: 20 May 2004, 16:04 »
um..
1.. use optimax.. lol
2.. clean the thottle body
would prob avoid the boost valve.. been hearing mixed reviews on those.
mrwotto
Re:response
« Reply #2 on: 20 May 2004, 20:14 »
optmix is definately worth using makes my mk3 run a hel of a lot bettter.
As for lowering spring i would go for spring and dampers personally, and i can tell u that u will notice one hell of a difference :)
Offline Overseer
Re:response
« Reply #3 on: 20 May 2004, 20:20 »
^ what suspension did u put on yours, and how much did it set you back?
mrwotto
Re:response
« Reply #4 on: 20 May 2004, 20:39 »
i put a set of g&n sprigns and dampers on mine which they had on offer at the lincoln branch of german and sweedish set me back about 250 quid, and has dropped the car by 40mm and makes it go round corners much better
Offline Overseer
Re:response
« Reply #5 on: 20 May 2004, 22:50 »
fitted yourself?
golfvr6
Re:response
« Reply #6 on: 20 May 2004, 23:46 »
If the car is unresponsive then it is worth checking the static ignition timing.
Offline Burnsy
Re:response
« Reply #7 on: 04 June 2004, 19:53 »
Then again you could just go and buy a VR6 ;)
Wooot by 100 th post had to say something to get it
marcus123
Re:response
« Reply #8 on: 07 June 2004, 09:06 »
k&n should give you a much sharper throttle response, definately get one as they will make it sound real nice as well.
not to sure abouit power boost valves, arent they a bit of a chav mod?
do they actually work? ???
Offline Overseer
Re:response
« Reply #9 on: 07 June 2004, 09:18 »
^ i dont think they do.. i posted about them a while back, read through.
