Author Topic: Engine cuts out within seconds of starting!!!!!!!!!!  (Read 1138 times)
AJH1973
« on: 04 October 2008, 16:59 »
Hope someone can help me again!! This time it's the engine!
The car starts fine but then if I try to accelerate it dies straight away. If I leave it idling it will idle for about 5 secs and then just die. I did have a few bits off the car last weekend, air box and air hose to the inlet manifold but as I say the car starts absolutely fine and runs smoothly before it cuts out??
Any ideas on what it could be??
Offline aj_golf
Re: Engine cuts out within seconds of starting!!!!!!!!!!
« Reply #1 on: 04 October 2008, 17:17 »
id say it was ur fuel!
is it injected or carb?
if injected check ur petrol pump
if its carb might jus be sh!tted up so jus clean it up....
AJH1973
« Reply #2 on: 04 October 2008, 18:14 »
Sorry should have put that in my original post!
It's 1.8 8v GTI . Don't think it's fuel pump as I can hear it kick it and it fires up and runs smoothly - although I suppose it might do this even with a duff fuel pump.
Offline mattkh
« Reply #3 on: 04 October 2008, 19:10 »
Hi
Put up a few pictures of the hoses at the back of the air box.
AJH1973
« Reply #4 on: 04 October 2008, 19:50 »
Had a bit more of a search on other threads and looks the issue may well be a leak somewhere so I'm going to take all the pipes off and give them all a good check- put it back together and keep my fingers crossed!!!
If this doesn't work I'll take some photos and pop them on here.
Offline daniel-1986
« Reply #5 on: 04 October 2008, 20:40 »
check ur fuses as  i had the autochoke fuse blow causing the same thing but mines a carbed engine but worth a check
AJH1973
« Reply #6 on: 05 October 2008, 18:36 »
Problem solved- re-traced all the bits and bobs I took off last weekend and found that the MAF lead wasn't fully home!!!!!! Next problem is I have got steam coming through the air vents when on max heat- looks like next w/e will be new heater matrix  :wink:
